I've ordered my 6266 today, will go on a fully built 26
Super keen to see how this goes, not just for outright numbers but response and midrange
Should be an animal on eflex, haven't decided on cams prob end up going poncams...
Edited by SiR_RB
:woot: I would love to know what your definition of "outright numbers" are if you call 6266 for response and midrange versus big power!! I assume given you didn't go 6262 or equivalent you intend on pushing the turbo reasonably hard?
My aim is for mid 400kw on I'm guessing maybe 24-26psi or so
Won't be pushing every last kw out of this setup just yet, gotta make do with my current fuel setup and lack of money after this build lol
Also gonna be using a GFB 50mm gate as my mate works there and can get them for a good price, undecided on manifolds but obviously 6boobs seems like the way to go....
Keep you guys posted with updates
I may have a slight rear seal leak already. somehow, and the cars still on run in, running spring pressure (seeing 10psi). turbs was primed properly and always warmed up/down. still not 100% yet, but if it is.. damn shame and will have precision on the phone askin for answers.
I got mine from real street performance in Florida USA
Had a slight delay with the rear housing but it left today should be here in 3-4days
coming in over 1k? they quote me about $150 for postage which blows
I bought most of my engine gear off these guys, $150 for postage from them is fair. It ships mega quick.
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
