.84 housing will do 500kW on an RB all day, nothing wrong with the housing choice. I pushed > 630kW atw through mine before I started to see signs of a restriction.
That's good to hear! What turbo were you running and at what PSI if I may ask.
6766 on 42psi SR20VET 636kW. This was nearly a couple of years ago and I'm still contemplating going back to this for the street.
Simon that's great power for a 6262. They are electric to drive on an RB.
sorry i didnt read through the whole thread but ive got a couple of quick questions.
Which turbo would be closest to matching a 35R with .82 rear?
whos the precision dealer of australia?
6262 probably the most sensible alternative - though I'd look hard into finding the cause of your failures, it is really unlikely that it is a Garrett specific issue... LOTS of people here and everywhere are using Garrett turbos or Garrett units based on Garrett cartridges, old and new with no way near the issues you are having - your car won't be taking specific objection to the turbo being Garrett, while it's hard to be sure I'd be a bit concerned we'll see a post about a Precision or something else failing in the near future if you put a new turbo on without changing anything.
It's 100% not the car. Everything has been checked. Double checked and then checked some more. I have all the correct parts and nothing pointing towards anything sinister ever pops up.
There have been a large number of failed garretts in the drift scene lately. Some of these cars have a Failed Garrett after a few days and then go on to run kandos for a long period of time with out issues
So yeah. I'm kinda looking at other options atm. How much for a 6262. What's the next size down from that?
Was it a GT35 Simon? What happened to it?
I have had brand new Precisions fail on customer cars, even before the tune, every manufacturer can have occasional problems I guess. Just seems those GT35 cores with plastic cage bearings aren't the best for hard work. No issues with any of the GTX's I have fitted, and mine has copped a hiding.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
