I'm currently doing a single turbo conversion on my GTR with a 6262. What have people done with the water lines since these turbos don't need them?? I'm trying to figure out best solution.
So the one coming from behind the head connected to the one from the front?? I'm a bit lost here not much info out there.
How about the one on the block down the bottom, just block that one off?
Mate finally bit the bullet and is ditching his GT3076R for a 5858 on his R34 Gt-t, was making a touch under 500 before so I'm guessing it will bump up to around 550 with not too much more lag
Went in for a tune last night. 525rwhp on 1.4bar and 555hp on 1.6bar before it started having valve spring issues top end. Higher boost looked like it was heading just under 600hp with 1.8bar.
Boost comes on around the same as the 3076R but makes a bit more power earlier (200rpm in lower range when ramping boost) and makes an extra 70-90hp on the same boost through the mid range and top end. Overlay with the T67 on my old green car and they were very similar but the 5858 will smash it with the valve springs sorted and some more boost.
Forgot to get a graph printed (will get one when valve springs are done) but it's probably the best mid size turbo I've seen on a RB25
TLDR; Comes on earlier and makes shit loads more power than a GT3076R
Edited by SimonR32
  • Like 4
Awesome results. I thought the 5858 would be laggier then the 3076 by miles and that the 5558 would be a closer match. Apparently not!
Im guessing .82 rear? BB version?
Technically boost builds a little slower on the 5858 but I guess it's flowing a bit more air so more power down low. Owner says it feels better low down on the road than the GT3076R as well
Yes and yes to the other questions
Edited by SimonR32
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
    • The old approach was to fill the cylinder/chamber with a length of rope pushed in through the sparkplug hole. The new approach is to connect compressed air to the sparkplug hole and fill it with enough pressure to push the valves up. Doing either of these things with the head on and the engine in the car is a lot less pleasant than doing it properly.
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
