Finally had the tune...
So stoked for the little rb25 with 647 hp @ wheels on 28psi.
It actually comes on the converter 200rpm sooner than the to4z.
I need cooler plugs and a bigger wastegate and it should make 700hp pretty easy as the 647 was with early shut off cos of break down and boost creep. image_11.jpg
  • Like 2
I am about to go down the 6262 (0.63 rear) path on my rb25. I'm chasing 280kw ish low boost and 320 - 350kw high boost. Engine is built and has supporting mods. Just unsure as to what gate pressure I should run for low boost. Fuel will be 98. Was thinking between 16-18psi low and 20-22psi high.
Small rear housing plus 98 isn't a very good idea imo.. I made 288kw on a GTX 3071 on 98. Id look at something smaller than a 6262 for 280kw.
That kinda power can be had on a stock lowmount position kinda turbo.
Big $$$ changing manifolds and plumbing up EWG etc for a laggy 280kw - 350kw IMO.
Edited by Mick_o
I drove a supra locally here that makes 350kw @ 16psi on a gt3582 with a 0.63 housing on 98. Looking to make 320kw+ in the high boost region, so it must be able to get there if the 3L can do it without it choking. If I have to run a little more boost to get there I will. Just trying to work out what spring I should be running in the gate for low boost to roughly get in the 280kw area.
5858 0.84
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
