On 12/19/2018 at 11:50 AM, feedmyfast said:
Yes, intend on staying with the T4 open housing so I won't have to spend too much money for an already expensive upgrade. I am definitely looking for some headroom for other mods (stroker / RB30) in the future. Looking for a turbo i can run now and not have to toss aside when i do the next setup.
OK, sortof makes sense.  When you do the stroker/RB30 upgrade is that for more power or more drivability?   Realistically a turbo which is "all in" in the low 4000rpm range on an RB25 isn't necessarily going to be that large a turbo on an RB30... or a turbo which justifies a solid RB30 build is going to bit a bit lazy on an RB25 unless you are actually targetting more of a punchy road car setup.
You could get a 6466 with a smaller T4 hotside for the RB25, and order a larger one for when you go with the RB30... just to try and take the edge off.   A 6466 would likely be "all in" late 4000rpm range on an RB25
18 minutes ago, SimonR32 said:
5558 on a RB25 with 20psi on 98
Going to be fairly rapid in a 240Z, especially once some E85 is used
That's a pretty nice long powerband - is this a Gen2 one?  What hotside?   It's fairly lazy for a 55mm turbo, though not so lazy for the power level
Edited by Lithium
The stroker / RB30 would be just to make more reliable power.
thanks for the suggestion! the 6466 with different turbine housings sounds like it would be the most flexible approach.
reliability comes from the engine builder and the parts used to put the engine together mate. I wouldn't say an RB30 is going to be more reliable than an RB25/26.
My engine has been in the car for 15 years now. Its made anything between 350rwkw to the now 500rwkw. Its a standard RB26 block with stock crank. About the only mods it has are some GReddy rod and pistons and some head studs. Standard crank bolts are in it even and we used to rev it to 9200rpm. Its nothing special but it was put together properly and that's why it has stayed together.
Reliable in the sense of less stress on the motor. A RB30 will make the same amount of power with less boost just to the increased displacement (in theory).
2 hours ago, feedmyfast said:
I purchased a 6466. should be installing it within the next few weeks. I'll post the new dyno graphs when I tune the car
Well done!  Presuming CEA?  Split pulse or single scroll?
Post up a couple of pics of the installation
Yes that is right. CEA GEN2 6266. Single scroll T4.
Will do! i can't wait to install it. just need a few things beforehand, (5 BAR map sensor, fittings ,etc). I was told the 6466 really wakes up around 25 lbs. I only have a 3.5Bar sensor,  so I would run out sensor range fairly quickly.
  • Like 1
On 1/3/2019 at 5:48 AM, feedmyfast said:
Happy New Years All! Quick update I purchased a 6466. should be installing it within the next few weeks. I'll post the new dyno graphs when I tune the car
Nice, what hotside did you choose?
  • 3 months later...
3 hours ago, Lithium said:
First time I've ever seen a 6870 come on earlier than a 9180, what other changes were made?
Direct back to back change... Same boost, 30psi
6870 made even more power with extra boost while the 9180 was all out
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
