have many people had much success with the 6266 turbo on a built 2.6?
coming from my old supra with a stock 3L (no cams etc either) with a 6466, the 6266 on my gtr feels considerably laggier.
It does seem to be the journal bearing (purchased the car with it on) which would certainly effect the transient speeds between shifts but I still thought there would be more lower in the mid range.
I've just completed a full service and its off for a retune this week so ill have a dyno sheet to put up soon
Interested in seeing 5862 as well. I have a 2.75L BC stroker build on stock bores (N1 block) and I want something super responsive for pumpgas on the street. I'm not one for E85 or racegas because they aren't really available in the area.
I'm betting my stroker, with Poncams A, ported head, +0.5mm SS valves, etc will run pretty dang good with the 58mm turbo.
Finally got my car tuned.@19 psi, 93 octane 611/449 tq on precision 6262. Lmk what u guys think
EC990DBB-75E3-4453-89C1-EC9B0C5E4339_zps
This pretty much has me convinced of the 6262. Are you on a stock stroke and/or displacement?
I have a BC stroker motor on new N1 block (std bores), ported head, SS valves, Tomei Poncams A, etc. I'm going for a nice response build.
Another shop is trying to get me to run their billet (not precision) version of the 6262 and I may take them up on it since he's offering a great price and warranty. He just wants to see what it will make on a good RB26 setup. They have made 640 whp on a stock 2JZ with their 6262 and wanted to see what it would do on a built 2.75L RB26.
What manifold is everyone running?? I don't want to have to change my R32 PS or A/C out to later.
Hey guys,
Just picked up a Precision 5858 off a mate that needs a rebuild. It currently has a .63 rear housing and I was curious if anyone has seen any results with this kind of set up on a RB25.
I've seen Rondofj's results with slightly smaller 5558/.63 combo and his car made 286kw with full boost around 3600-3800rpm. So I'm assuming I'd have no issues running a 5858 with the same rear housing ... might make the magical 300kw mark too? (kinda all I want on a unopened RB25 for drift anyway).
My guess is it would be responsive as f**k, just wondering if it'll choke in the top end, and/or cause excess exhaust heat/restrictions etc.
Thanks!
Edit: I saw the 5858 on the RB25 neo on the last page too, very impressive!
1998 R34 GTT
Stock RB25DET NEO
3" metal intake
Z32 afm
Precision 5558 0.63a/r turbo- ported cover
Turbosmart Compgate 40mm off turbine housing
Cooling Pro FMIC
Stock exhaust + intake manifolds
3" dump with plumb back
100 cell metal cat
3" exhaust
Siemens Deka 60lb injectors
Walbro GS3442 fuel pump, direct voltage
Nistune
Yellow Jacket coils
286rwkw @18psi, intake temps getting hot, will change piping and crank boost up later, and post dyno sheet when I have access to a computer
Edited by Run-It-Hard
I saw that last night
Should go awesome, same HP rating as a 6266 with less lag !
Less lag will be a stretch, just because the wheela are smaller doesn't negate the fact it's pushing 50hp more of air. Keen to see results though, could be a downgrade/upgrade for me
Wound the 6262 up a bit more for racewars this weekend
Effing-A that is some good power!!! All this on a STOCK bottom?!?!
As a mechanical engineer I LOVE reading data and sorting through turbo selection and compressor maps...none of which Precision provide...but DAMN the numbers don't lie!!! I guess they let their powerbands do the talking. This turbo would be sick on my stroker motor.
I have to ask, why do so many people keep the revs down on their dynos? Am I crazy in thinking mine will go 8-8500 no problem?
Edited by HarrisRacing
You'll notice it pretty much makes peak power at 5-5500rpm.....no point revving it to 8k.
Green line is power. Power peaks all the way near 7500. Even if the power stays over 600 above this, there is still a reason to stretch the powerband out and have the tune in place for the revs. I am curious if the engines can do it is all...maybe this is too much to ask for the stock bottom end?
So it is.
A built engine will rev beyond 10k if you want it to...i.e. Massive turbo.
Limiter is at 8800, kicks in around 8500... I'll change around 8500 on the weekend.
I think the dyno was just set to limit at 8000
Edited by SimonR32
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
