I bought one of those syphoning hoses with the jiggly ball at the end that u stick in the tank through the filler and jiggle (rather than suck on the hose) but it stops about half a metre in, i'm guessing there's some sort of protection mesh in there to stop junk from falling in to the fuel tank by accident. So the hose is out..
I've read that the fuel pump can do the job by simply unhooking one of the fuel lines and turning the key to the ON position and let the fuel pump spit it all out. But where do I unhook the fuel line ?
It's an R34 GTT .. I can see the fuel line on the left hand side coming into the fuel filter .. do I disconnect it before the fuel filter or after and if so where ? Cheers
Oh yeah ..car's been sitting in the garage for 6 months with half a tank of ultimate ..something stinks really putrid, I hope its just the fuel and not some small animal that made a home in there somewhere, lived a happy life and then DIED.
https://www.sau.com.au/forums/topic/316680-how-to-get-old-fuel-out-of-car/
ok i've unplugged the fuel line on the fuel rail (just after the filter) and when switching the key to ON I can hear the fuel pump priming and it squirts about 50ml of fuel then stops
At that rate I will have to switch on/off about 500 times which i'm sure would kill my fuel pump and battery and take ages .. Is there any way to get the fuel pump to keep sending fuel without stopping ???
I'm about to take the fuel filter off and see if it keeps flowing without the fuel filter on the line but somehow I doubt it ANYONE ?!?
Not 100% on this...is the fuel pump actually located in the tank in the 34 or remote..
Maybe access the fuel pump, from the boot area (under the step in the boot luggage area ) and u might be able to use the pump that u got that way...
just throwing it out there.. may or maynot work?!!?!?!
Correcto!
Just short the pump. Don't let it run dry for too long though, because they tend to depend on fuel for lubication of the pump :D
How do you short the fuel pump though ? I've already searched for "short the fuel pump skyline" and whatnot earlier today on teh google but came up with nothing useful
hm come to think of it I do have that nissan consult cable and some software somewhere ..wonder if any of those programs can be used to make the fuel pump run at full speed to empty the tank
edit: yep looks like NIssan Datascan which I bought last year has a 'fuel pump' active test so that should do the trick ..will report tommorow
those jiggle syphon hoses are a bit of a pain. a much better setup to use is a boat fuel line setup. they have the bulb in the middle of them that you squeeze to such the fuel though.
also while you can use the fuel pump, it may take a while to do so. depending on how much of a hurry you are in it may be quicker to remove the panel in the boot where you access the fuel pump through and just syphon it out through there. it is a bit more fiddly to do but you will be able to syphon the fuel out quicker. but thinking about it, the extra prep time probably outweighs the gains from faster syphoning.
i usually just pull the cas out of the car and rotate it by hand, this will keep the pump on, dont fun it flat out without giving it a break. you will then have to retime the engine or use the marks that you should have written on it, however they are not always 100%accurate
What are you going to do with the fuel once you get it out of the fuel tank?
Frankly I wouldn't be worrying about it. The fuel will still run the engine. Once you get the car out of the garage, the smell should dissipate (if it is just the fuel).
^^^ yep or just get some more Ultimate in a can and pour it into the tank if you're concerned about starting it and then driving it to the servo to dilute the sulphur smell/effects.
Sulphur can vary in its %age by up to 100%
http://www.kittiwake.com/4_7_sulphur.com and yes, I'm aware that %ages can vary quite a bit from country to country as well as between brands - or even batches within brands.
Edit: lets's try that again... http://www.kittiwake.com/4_7_sulphur.htm
datascan couldnt do it ..same issue as switching ignition to ON ie. only pumps a small amount then stops.
I used Yavuz's (unigroup) suggestion which was to have the fuel return hose disconnected and run into a container .. start the car and run it until its out of fuel. Took about 10 mins with half a tank. Easy as :D I'm hoping the fuel filter picked up any nasty crap before it could clog my injectors.
Anyway, fresh BPU in there and the car drove without any issues.
    • Yep it sure does.   Tone wheel lines up in the same spot perfectly.
    • Something I meant to say when we were chatting the other night about having an open trailer floor being great to work on a car, but you've never used the feature... It's a great place to park a car after doing suspension component changes, and do the tightening of all the bushes with the car sitting at full ride height. Especially when you don't have a 4 post hoist!
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
