  • Replies 78
So what is "wrong" with it as far as the RWC goes?
I'd love to buy this dude!
AWESOME CAR!
Worth more than your asking, i dunno what these crack heads are on about but you will easily get that!
Are you throwing in the Power FC for free with the car?
I mean with that in and tuned i'd expect, what...... 250-300rwkw?
RWC comes down to searching around and finding someone that will do it. when i find a buyer, then we'll just have to work together to find someone. but it can be done
the powerfc does not come in the car. that is a seperate sale.
i was planning a pretty conservative tune and would be happy with anything between 230-250 rwkw. but obviously the turbo is good for more than that.
Hey man just a few questions.
Where abouts are u located? Would u do 20 with a rwc included?
What sort of aftermarket manifold is on it, as i can see the turbo is high mounted....
Interested
ThanX man
Simon
gday. welcome to my thread.
im in melbourne also.
the car is sold as is. BUT im sure we could work something out. apart from rear tyres and turbo/wastegate setup, it should be rw.
i think the manifold is HKS, cause it seems to be a complete kit and its the same as pictures on the net. but it doesnt say HKS anywhere. it is stainless steel, and its just had some cracks welded up and the plate trued. and wrapped in exhaust wrap.
peace out
I have a trusted Mechanic who happens to be a family member and has looked at a few cars that " looked ok" but found many hard to pick things and has prob saved me thousands of $$ in the long run so i get him to check everything out for me and he wouldnt have the time for a trip to melbourne.
Sounds paranoid but its not much different to importing a car from Japan, minus the language barrier.
Dude, i'm not interested in buying the car, but i wanted to comment on how sweet it looks. Awesome and cheap. Maybe you should sell it for more as people might think it's stuffed for the price you're asking :)
Anyway a free bump. Good luck with the sale.
Scott
hmmmmm i dont think that is the reason that people arent buying this car. i think it is because most people that want an r32 are looking to geting one for closer to 15g and that is up to them. i think you need to have a love for 32 to want this car (i am one of them :) people think just because you car get a 32 for 7g under the new 15 rule that all of them should be cheep "not the way it happens!"
good luck with the sale - if i sell my car befor this car goes i will be in contact.
regards, jonathan
hmmmmm i dont think that is the reason that people arent buying this car. i think it is because most people that want an r32 are looking to geting one for closer to 15g and that is up to them. i think you need to have a love for 32 to want this car (i am one of them :P people think just because you car get a 32 for 7g under the new 15 rule that all of them should be cheep "not the way it happens!"
                        regards, jonathan
yeah i always knew that would be the case.
its no surprise that most of the people giving the car props are owners of r32s and/or modified cars in general.
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
