  • Replies 114
Paint the floor is like the other guys said is the first thing I would do. Easy to sweep up dust and oil spill plus it lights the place up a huge amount. We painted the work floor in some generic paint and 3 years later it hasn't bubbled or scratched though. It had had a fair bit of oil on it to before painting. Also paint the walls white. It refects the light off the walls so you don't get the shadows when working in the engine bay or inside. I have one single car shed with 2 fluros and a double car with 2 fluros. The double has painted walls and is brigher than the single car garage.
I haven't done it yet but have been thinking about getting some free standing secondhand food prep benchs off ebay. Pretty sure the sell for around $150 each. Full stainless steel frame and top. Some come with sinks also.
If your staying there for a while mount a few random power points and plumbed in air line with a few outlets, one on the bench and one near where you work on the car and one near the door. Works great with the coil air lines. Saves having a hose and compressor your alway tripping over. Only would cost prob $150 to do.
If somebody knows where to get cheap pallet racking let me know.
some great discussions but pictures speak a thousand words, love the tyre racks but how have you built your benches. Do you have storage sections and what about backing boards.
2 hours into cleaning, still a shit fight. I just don't have enough storage space. The track car normally lives where i'm standing, street car on the back slab.
On the plus side, when it's clean i have a nice open well lit area for working on stuff.
haha ,nice post.
hre is the workshop i have at the moment with a friend (mooving out in a few months to my own, friends need to convert it back to wood workshop for his buisness. but still will have around 150m2 to do my stuff in the new place, see how that one turns out)
paint i used , was a pretty cheap one, payed about 500$aus for around 350m2 (all peeeeling of right now), couldnt afford the good epoxi stuff back then (and didnt not want to spend that much on a property that was not mine :( )
pics of workshop when it started:
The workshop:
Chassi room:
Paint room:
Engine room:
my engine out :ermm:
my 2 ugglys:
engine in bits:
Tyre racks:
My car in the chassi room:
the built this:
some froends coming to visit:
hope i can make a cleaner and tidier workshop in the next place i go :rant:
keep pics coming dudes, need ideas :(
hahahahah, thanks guys :rofl2:
there is a fridge hehe, but no beers :D (i drank them all heheh)
will post a few pics of new place in a few weeks :P, at least this one has tile floor, so no need to paint hahahah, yuhuuuuuuuu.
pmr-33, yes its under the owneds house, the one keeping the place..........
Who needs a house when your garage/workshop is that big...
you need a house to store all the shit that doesn't belong in the workshop.. Ladders, paints, camping stuff, seasonal stuff... That's all gotta go somewhere, so you need a house
Finally got some of mine. Not that elaborate and certainly not going to get anyone exicted. But it is very functional for everything I use it for. The last pic is of a mobile bench I made up to have a portable access to my main tools.
Future possibles. Behind the brickwall (behind the punch bag) is just shelving and the Hot water unit. I am considering knocking that wall out and putting in more shelving and a tirerack and moving the hot water unit outside to get it out of the shed.
Please provide any thoughts/ suggestions/ critisizims as I really want to make it bigger and better.
Nice one!
Would love a hoist, but I don't have the roof height.
I work on my car while it's parked on my trailer a fair bit. It's good as it makes the car a nice height to work on. I can jack it up on the trailer also.
But nothing beats a hoist.
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
