From the Targa update feed, aren't these guys in the TOUR, not racing! :)
"From TS10, car 56, Sebastian Lip and Brett David in a 2009 Nissan GT-R 35, had an off 1.7km into the stage. They found the car behind a shed, with some fence damaged ……. Both crew members are okay. "
Quinn cuurently in 3rd, with Jones in 5th.
Steve Glenney doing a great job in the RX8 in 2nd.
https://www.sau.com.au/forums/topic/318577-targa-tasmania-2010/
From the Targa update feed, aren't these guys in the TOUR, not racing! :D
any word? i hope everything is ok.
Good to hear that Sebastian and Brett are OK.
It looks like the weather was wild at Targa today - video here ...
Looks like there have been quite a few cars damaged - video here of some of them :merli: ...
Photos are being posted here of the event ...
http://www.sportcom.com.au/targatasmania/i...1&Itemid=68
Videos are being posted here ...
http://www.sportcom.com.au/targatasmania/i...8&Itemid=61
- The Tuners Group
Edited by TheTunersGroup
wow some shit went down today... nasty nasty. lucky me gets to watch them from my backyard on sunday!! grass tree baby
not sure exactly, someone stacked it, and I think Glenney in the RX8 stopped to check if everyone was okay and another car cleaned everything up but the possums =(
Edited by Mr. Untouchable
no the opposite unfortunately.
Ayresy in his immaculate 400R stopped to help and Wwilfred cleaned him up in the borrowed Rx-8.
Good to see all the R35s staying on the track including domonic from here. Hope I didn't just put the mocker on anyone.
My guys have had mixed luck, Kel is going great in the R32 (or ATTKD special if you prefer) in 9th in Early Modern. Mark is running a wide body gtst since he had to pull the front drive shaft after a diff blow up - nowhere on the board but still having fun.
Ours came close to disappearing a few times.
http://www.flickr.com/photos/90747317@N00/...036746916/show/
Arhhh the hottest R35 getting around! Post up the vid Dom...*giggles*
Hope to see you at another one of our supersprints soon! :) Will gladly take the 35 for a lap or two again for you :D
Are you doing Targa Hi Country???
Great photos Dominic - this photo is epic ...
http://www.flickr.com/photos/90747317@N00/...57624036746916/
- The Tuners Group
Hi Dom, Tim here from the Porsche 944 (#736) we were usually in the que together at the start of stages.
I must say you always had a grin on your face so you must have been enjoying yourself! I always got a great chuckle out of the stickers on your rear bumper!!!
Hope to catch you at more events soon!
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
