Gotta use Harry's timer.
Cheap as and pretty good. at teh start of your day, you set a point of interest on the pit wall. This is your start finish line, then away you go :rofl:
If we do a track walk around you can even set sector points.
http://web.me.com/hschlangmann/LapTimer_Homepage/Home.html
Hey NISMO, I just downloaded it. Looks ok, have you used it before?
Does that mean your the one I come and hassle when I can't get it to work?
Oh yeh, can you put wakie into it as one of the tracks?
  • Replies 566
Hey Dave,
haha, def will be happy to help stuff sorry set it up.
It actually works pretty good. It all works of GPS signals, so as long as you set your start/finish point its good to go. You also only have to do this once. eg I set Oran Park on it, used it on the GP circuit, went back 4 months later to do a south circuit day and it remembered the point and simply started timing laps once i turned it on.
Given the the iphone's GPS is not the best you do get some odd laps, but in general its good to see how you go across the day.
For $5 (what i paid when it was first released) its pretty decent.
Unfortunately it doesn't seem that Wakie is on his list of pre-programmed tracks. Will shoot him a mail about how to get it added, so far he's been very good with set up help.
Thanks mate, price has gone up though now 7.99 still a very cheap laptimer IMO
keep you eye out for a guy in a red 33 (plates:GR33DD) waving an iPhone around in the air looking really confused, that will be me.....hahaha
see you there
racechrono is better, you dont have to have a silly iphone and its free :rofl:
does the iphone allow use of an external bluetooth GPS receiver? none of the built in GPS units are particularly fast and you get a much more accurate lap/stats using an external one.
umm, I don't think they do but I could be wrong. I know I could never get a bt connection with some of my mates nokias when I first got the phone but I haven't checked it since the last couple of firmware upgrades.
Surely this app will be better than trying to use a stopwatch?
BTW you know the only people who hate iPhones are the people who don't have one...lol....nah mine give me the shits a lot of the time
better than a stop watch yes, its mainly the GPS trace of your laps that takes a hit using the internal gps and the timing is closer to being within ~0.5s as they only update once a second vs the higher end bluetooth ones that update 5 times a second, though that gives you an excuse when you go off the track it was the GPS being random not you :rofl:
:P
Thanks Shell. As a driver. I thought so but wanted to confirm.
I've been a member for a while now (joined last year) but never received anything. Was I meant to get a membership card or something? Only reason I know that I am a member is that I have access to the NSW members section.
Full Name: Ray Dean
Car Type: Nissan Skyline GTS-R ... R31
Newb or not: Not
Most recent lap time if not newb (can be another track if necessary but make sure you mention which one):
# of Drivers: 1
# of Passengers & Name: 1
Full Name: Ray Dean
Newb or not: Not
# of Drivers: 1
I knew "Shell" was an alias!
Monies paid today at Mortdale
Reference of wizard/ wakefield.
Full Name: Ron Lea
Car Type: 300zx
Newb or not: Not
Most recent lap time if not newb (can be another track if necessary but make sure you mention which one): 1.11.31
# of Drivers: 1
Hope the weather is good. :bunny:
I'm in!!!
Full Name: Zane Robertson
Car Type: Nissan Skyline R32 GTST
Newb or not: more newb then not
# of Drivers: 1
# of Passengers & Name: 1 - Melissa Meins (Melly)
will transfer passenger money now (forgot about it when i entered)
I've used Harry's Lap Timer with the tom tom cradle and it works ok. You need to jailbreak if you want to use a bluetooth GPS. I have the wakefield start/stop line co-ordinates - you just put it in as a point of interest IIRC.
Co-ords please mr stabby!
+1.
Actually, have you used the export lap feature?
If yes, pick a clean lap, export it to your email, and send it to Harry's site. He should be able to use that to add Wakie to his track database :bunny:
Full Name: Mark Waugh
Car Type: Hyundai WRX
Newb or not: newb
# of Drivers: 1
Full Name: Ryan Boslem
Car Type: R33 GTST
Newb or not: Newb
Most recent lap time if not newb (can be another track if necessary but make sure you mention which one): 1:11.76
# of Drivers: 1
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
