I'll be at the best western in the city centre.
Prue, I think the "regular" thing that people have been talking of is going to the Workers Club.
Oh, and the only thing I'll have to do is change the tyres over and clip the harness in...
I can't remember any day that I haven't been up till midnight doing stuff to the car...
  • Replies 566
I have to get my Wakie licence so was thinking of getting there about 730????
I'm not sure wether any staff will be there at that time though. It's my first track day so I do t really have a clue what goes on, better to be early and have time up your sleave IMO
I am taking GTRSean's spot. I am making payment to him today.
I will be in my Triumph TR8 with no passengers. Last time out in it out Wakefield 2 up and on street tyres I was running a 1.16. I am happy to nominate that time for the day but hopefully will be running a little quicker!
cheers
To my dearest Ando,
My Wakefield licence has expired, so has my CAMS licence. I have renewed my CAMS licence online and have the receipt, jsut have not got confirmation in the mail yet, so I will bring this receipt to show its paid and organised.
Love
Andy :)
To my dearest Ando,
Love
Andy :)
Dearest Andymoomoo,
Thank you for notifying me of your current license status. Unfortunatley your communication is pointless to me, but must be addressed with Wakefield park admin upon sign-on. I believe in past they accept an official letter from CAMS, but i think you have to contact CAMS and ask them to fax you a temp license.
Otherwise, worse case scenario, just buy a $20 Wakefield day license. I'm sure your funds will allow for such expenditure.
Kindest Regards,
Ando
Anyone? Plz pm me if your selling a spot.
Mate so far i believe it is as follows with selling/allocations of spots
Sellers:
Aggroman --> Sold to ???? (please let me know details)
GTRsean --> Sold to Ravenoak
Tonba --> Sold to ???? (please let me know details)
Black Beast has spot for sale
Liz has spot for sale
Potential Buyers:
Mcready
Majanal
Deano1
Now i will keep everyone updated as best as possible with refunds/swaps etc.
But can Aggroman (dave) & Tonba (alex) let me know who sold too pretty please, name and car/potential times!! :)
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
