does anyone know where to buy a minispool for a R32 GTST?
what specs do I need to look out for and will the same mini spool fit any other cars? ie.. do I look for a R31 mini spool or something.
Cheers
Dan
Sell you a new diff cheap :thumbsup:
I thought the 32 had a borg warner :S
Was just thinking that if I weld it, if the welding breaks I will be stuck on the side of the road.
So should I just shim it up? I just want it to be predictable.. at the moment it reverts from twins to singles and it snaps back and piss's me off. Also picks up a tyre through a corner and spins it and Cant get the power to the ground evenly.
Edited by BANGN
and if you put anything in that has the same effect as a minispool has a chance of breaking axels so either way... your stuck on the side of the road...
Spool on weld can break axles , welds can break resulting in pinion ,crownwheel damage or launch shit out off housing :(
Can only shim clutch type diffs, most basic Nissan use Viscous diffs.
Aslyls S14 Racecar has been on a welded GTR diff without problems. GTR is easy as you can weld the clutch plates so if the weld fails it just goes back to normal GTR LSD, If you weld other types you need to weld the spider gears and when they break shit goes everywhere.
There is a tutorial in the DIY area of the forums with a guy shimming an R33 diff.
Fairly sure R32 would be similar, he's posted step by step photos and price lists for the shims as well.
I think 3.2mm (two 1.6mm shims together) is tight enough to chirp tyres while parrallel parking etc.
It will wear out eventually but should last for a good while.
I'm sure someone of your mechanical aptitude (aren't you a tradie?) could do it at work for the price of the shims/diff oil/gaskets etc :yes:
Don't weld it up/put a minispool in. I found with my old locker in early RX7, rainy days actually required me to get sideways to go around certain corners. It's easy too do because it's so predictable but would hate to have a cop around when you have to do it.
Edited by dave_rb20
    • They are, a good friend of mine bought one to replace his blow factory turbo, running a Toshi Tune reflash. Just use their supplied water/oil lines and you're good to go. At the time, they were like $900 delivered.
    • This is an option for 100% bolt on, the GCG high flow -  https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html Also, I'm pretty sure hypergear does a high flow that is 100% bolt on, it just doesn't make as much power as their bigger high flows.  Even if you get a hypergear turbo that requires you to chance the intake piping, it is a really simple modification. It can be as simple as a piece of silicon hose and you pop a filter on the end. It doesn't have to be some crazy pie cut titanium work of art intake pipe.  If you have the ability to swap the turbo yourself, you would be able to sort the intake piping out.
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
