How can I kill the reverse beeping sound? Its driving me nuts.
I am about to pull out my radio and thought I might be able to cut the wire or something along those lines.
Any help is much appreciated. :P
Chris.
On mine, the indicator ticking sound stops when reversing - so if you cut a wire it's likely you'll lose the indicator sounds also.
there is probably some sensor in the shifter that could be cut or tricked. Have a look in the V35 workshop manual....would be the same wiring.
I'm keeping mine because it annoy's the wife......and thats a good thing :P
Edited by Jetwreck
you'd think so but the amount of people iv seen take off backwards at the drags is ridiculous, after going over the staging lights they reverse back and dont put it back in first or D makes me LOL every time.
i saw a dumbass do this at the lights. (traffic lights) and back into the car behind.
Can't say I've noticed it. I know for sure it beeps once when I put it in reverse, and the reverse camera fires up on screen...but I don't recall hearing any further beeps. Maybe with the factory reverse camera the beeps are disabled?
Nope, they're there. I have the factory reverse camera and the thing beeps at me constantly when in reverse.
Doesn't really bother me though, I mean it is only beeps and it is not like I drive to work in reverse :blush:
  • 9 months later...
Chris.
lol...I know the pain...just hum to yourself while reversing....then you cannot hear it!
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
