All numbers are the stock car only with the bolt on Catback System
All numbers are manufacturers claims.
Naturally feel free to add to thread if you any addition info :wub:
GTR Exhausts RB26
EPA Test RPM: 5100rpm
Stock Exhaust at EPA Rpm
R32 GTR - 94dB @ 5100rpm
R33 GTR - 92dB @ 5100rpm
R34 GTR - 93dB @ 5100rpm
Trust GReddy PE Ti-R Power Extreme Titanium Muffler Nissan Skyline
R32 GTR - 93dB @ 5100rpm
R33 GTR - 95dB @ 5100rpm
BLITZ Nur Spec RX Muffler Exhaust System
R33 GTR - 93dB @ 5100rpm
BLITZ Nur Touring Muffler Exhaust System
HKS Silent Hi-Power Muffler
R33 GTR - 98dB @ 5100rpm
Trust GReddy Power Extreme II Muffler
R33 GTR - 99dB @ 5100rpm
HKS Hi-Power 409 Muffler
GTS-T Exhausts RB25
EPA Test RPM: 4800rpm
Stock Exhausts
R33 GTS-T - 87dB @ 5100rpm
R33 GTS-T - 99dB @ 5100rpm
HKS Hi-Power 409 Muffler Nissan
R33 GTS-T - 98dB @ 5100rpm
  • Replies 69
Soure: Blitz Website
Stock Exhausts - Not sure what rpm these are recorded at
Toyota
Toyota Aristo - 78db
Toyota MR2 - 94db
Toyota Supra 1JZ-GTE,7M-GTE - 85db
Toyota Supra 2JZ-GE - 82db
Toyota Supra 2JZ-GTE - 87db
Toyota Soarer 1G-GTE,7M-GTE - 83db
Toyota Soarer 1JZ-GTE (May 91 - August 96) - 83db
Toyota Soarer 1JZ-GTE (August 96 - April 01) - 84db
Toyota Celica 3S-GTE (September 89 - Febuary 94) - 88db
Toyota Celica 3S-GTE (Febuary 94 - September 99) - 83db
Toyota Chaser 1JZ-GTE (October 92 - September 96) - 84db
Toyota Chaser 1JZ-GTE (September 96 - August 98) - 86db
does anyone know what muffler configurations these exhausts have?
i need to get a 3.5" exhaust with large mufflers in it and its cheaper to get a jap cat back and change the rear canon to a large muffler than get a custom made exhaust if there is already a decent sized mid muffler (not a hotdog)
I was looking for a EPA friendly (less than 90db exhaust for the R33 GTR) but it appears they dont exist....even stock. So it looks like the custom route is the only way. Has anyone ever found a way to pass EPA with a custom made exhaust and if so what sort of set up.
Nissan
Nissan 180sx CA18DET - 88db
Nissan 180sx SR20DET - 85db
Nissan Silvia S13 CA18DET - 87db
Nissan Silvia S13 SR20DET - 85db
Nissan Silvia S14 SR20DET - 83db
Nissan Silvia S15 SR20DET - 88db
Nissan Stagea RB25DET (September 96 – August 98) – 80db
Nissan Stagea RB25DET (September 96 – October 01) – 82db
Edited by FrangaR33
May worth giving Racepace Motorsports a ring and find out how quiet their custom exhaust are.
But they're not cheap though.
90-91dB as tested on my car.
Mine is first gen, there has been another created since.
So basically the only conclusion one can draw from this is, Nissan, Japanese Performance part manufacturers = FAIL. Racepace = Awesome.
Racepace said they make the exhausts mainly so race cars get good high flowing exhausts that dont get them kicked off tracks for breaking DB limits, they dont guarantee that it will pass a noise test.
The jap companys (and most aftermarket exhaust companys) are catering to a market that 90% of people who buy them want more noise not less/the same as factory.
Japan also has a 92db limit so factory they can be louder than here.
^ Depends on the motor.
You can draw whatever you want.
The actual conclusion is that a very well designed system can be 3.5" and be very quiet. That is all the aim was.
They were not built to pass EPA. Main creation was for quiet track cars, and good flow for 400rwkw or so as stated.
Customers wanted performance of the circuit, with a exhaust level that would not see them defected contstantly.
Most jap exhausts are just too loud as there is a bit different betwee 94-95 dB and 90-91dB.
A Racepace system will easily cost you double what off-shelf Jap one will, I tell you that straight up.
I'm confident other places could build similar exhausts, but again they won't be cheap either as the mufflers are $$$
I've gone from being heard a block away (108dB), to people not even noticing my car pull up anymore :P
i thought an epa test is only measured to 3000rpm?
good info none the less
According to the ESMP (Engine Speed At Maximum Power) EPA Manual It specifies the EPA test for a:
RB26DETT - 5100rpm
RB25DET - 4800rpm
Yeah I know about the 92db limit in Japan, its just a pity we dont have any manufacturers (that I know of) making EPA compliant after market exhausts here, especially considering the fact a stock exhaust wont pass. They would make an absolute killing.
Edited by FrangaR33
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
