All numbers are the stock car only with the bolt on Catback System
All numbers are manufacturers claims.
Naturally feel free to add to thread if you any addition info :wub:
GTR Exhausts RB26
EPA Test RPM: 5100rpm
Stock Exhaust at EPA Rpm
R32 GTR - 94dB @ 5100rpm
R33 GTR - 92dB @ 5100rpm
R34 GTR - 93dB @ 5100rpm
Trust GReddy PE Ti-R Power Extreme Titanium Muffler Nissan Skyline
R32 GTR - 93dB @ 5100rpm
R33 GTR - 95dB @ 5100rpm
BLITZ Nur Spec RX Muffler Exhaust System
R33 GTR - 93dB @ 5100rpm
BLITZ Nur Touring Muffler Exhaust System
HKS Silent Hi-Power Muffler
R33 GTR - 98dB @ 5100rpm
Trust GReddy Power Extreme II Muffler
R33 GTR - 99dB @ 5100rpm
HKS Hi-Power 409 Muffler
GTS-T Exhausts RB25
EPA Test RPM: 4800rpm
Stock Exhausts
R33 GTS-T - 87dB @ 5100rpm
R33 GTS-T - 99dB @ 5100rpm
HKS Hi-Power 409 Muffler Nissan
R33 GTS-T - 98dB @ 5100rpm
  • Replies 69
Soure: Blitz Website
Stock Exhausts - Not sure what rpm these are recorded at
Toyota
Toyota Aristo - 78db
Toyota MR2 - 94db
Toyota Supra 1JZ-GTE,7M-GTE - 85db
Toyota Supra 2JZ-GE - 82db
Toyota Supra 2JZ-GTE - 87db
Toyota Soarer 1G-GTE,7M-GTE - 83db
Toyota Soarer 1JZ-GTE (May 91 - August 96) - 83db
Toyota Soarer 1JZ-GTE (August 96 - April 01) - 84db
Toyota Celica 3S-GTE (September 89 - Febuary 94) - 88db
Toyota Celica 3S-GTE (Febuary 94 - September 99) - 83db
Toyota Chaser 1JZ-GTE (October 92 - September 96) - 84db
Toyota Chaser 1JZ-GTE (September 96 - August 98) - 86db
does anyone know what muffler configurations these exhausts have?
i need to get a 3.5" exhaust with large mufflers in it and its cheaper to get a jap cat back and change the rear canon to a large muffler than get a custom made exhaust if there is already a decent sized mid muffler (not a hotdog)
I was looking for a EPA friendly (less than 90db exhaust for the R33 GTR) but it appears they dont exist....even stock. So it looks like the custom route is the only way. Has anyone ever found a way to pass EPA with a custom made exhaust and if so what sort of set up.
Nissan
Nissan 180sx CA18DET - 88db
Nissan 180sx SR20DET - 85db
Nissan Silvia S13 CA18DET - 87db
Nissan Silvia S13 SR20DET - 85db
Nissan Silvia S14 SR20DET - 83db
Nissan Silvia S15 SR20DET - 88db
Nissan Stagea RB25DET (September 96 – August 98) – 80db
Nissan Stagea RB25DET (September 96 – October 01) – 82db
Edited by FrangaR33
May worth giving Racepace Motorsports a ring and find out how quiet their custom exhaust are.
But they're not cheap though.
90-91dB as tested on my car.
Mine is first gen, there has been another created since.
So basically the only conclusion one can draw from this is, Nissan, Japanese Performance part manufacturers = FAIL. Racepace = Awesome.
Racepace said they make the exhausts mainly so race cars get good high flowing exhausts that dont get them kicked off tracks for breaking DB limits, they dont guarantee that it will pass a noise test.
The jap companys (and most aftermarket exhaust companys) are catering to a market that 90% of people who buy them want more noise not less/the same as factory.
Japan also has a 92db limit so factory they can be louder than here.
^ Depends on the motor.
You can draw whatever you want.
The actual conclusion is that a very well designed system can be 3.5" and be very quiet. That is all the aim was.
They were not built to pass EPA. Main creation was for quiet track cars, and good flow for 400rwkw or so as stated.
Customers wanted performance of the circuit, with a exhaust level that would not see them defected contstantly.
Most jap exhausts are just too loud as there is a bit different betwee 94-95 dB and 90-91dB.
A Racepace system will easily cost you double what off-shelf Jap one will, I tell you that straight up.
I'm confident other places could build similar exhausts, but again they won't be cheap either as the mufflers are $$$
I've gone from being heard a block away (108dB), to people not even noticing my car pull up anymore :P
i thought an epa test is only measured to 3000rpm?
good info none the less
According to the ESMP (Engine Speed At Maximum Power) EPA Manual It specifies the EPA test for a:
RB26DETT - 5100rpm
RB25DET - 4800rpm
Yeah I know about the 92db limit in Japan, its just a pity we dont have any manufacturers (that I know of) making EPA compliant after market exhausts here, especially considering the fact a stock exhaust wont pass. They would make an absolute killing.
Edited by FrangaR33
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
