  • Replies 227
Damn, look at all those 50's!
The long wang really kills it for us NA boys. I actually thought I went quite quick through the LW this time around (at least on the run I didn't spin out), but still ended up way down the bottom. I've got to make up the points on the skid pan, and as Gerald has shown we Supra's aren't complete boats out there!
It's interesting going back over past DECA results to see where you're improving. My LW seems to be getting slower, is that because clockwise is a slower track? MW seems to be getting progressively quicker! Down from an original 33 seconds to mid 29's. Probably explains why I'm loving it more and more too.
I think next time I'll tackle the cones on the wangs a bit faster, I'm sure there's plenty more grip in the car.
after scrutinising the results i had a decent amount of top 20 results but i got let down by a couple of slowest times (damn that cone i took for a ride)
all in all very pleased with it :)
I'll have to try it, I've never been good with the whole heel and toe action.
Come past one day I'll teach ya :P
Once accomplished Kez, aim to double clutch heel toe which will not only stop the jerky downshift, but will save your synchros a lot. This involves what Hamish described but you let the clutch out in neutral as you blip, then clutch back in before selecting the lower gear.
Yep that's where it's at, you get into such a habit that you end up doing it without thinking about it. I reckon it's easier to learn double clutching and then progress to heel and toe so you have an understanding of the rev matching concept.
I learnt just doing it while I was driving around town.
I.e. RoundABout's etc
start by learning to blip the throttle without worrying about the brakes
you will quickly learn how much you need to press it to get the revs matched
then you can learn to do it with your heel (or you can also roll your foot like I do with my size 14's)
Yer roundabouts are the best for it. I learnt the heel toe action in an automatic of all cars lol, just in neutral to practice the amount of pressure needed.
warning. you may send your passenger through the windscreen the first couple of times :P
LOL
Booooo not happy with results. Did worse than last time lol. Big improvement on the wangs but sucked a big one on the skidpan, complete reverse of how it normally is for me...go figure. Congrats to the winrars.
well done to the winners!
dane- blistering pace in your road car!
some cracking times amongst the field aswell, which shows quite a few people capable of knocking on the top of the table...
perhaps we should look at banning rear engine cars? :P
some great pictures from various people as always.
best fun i've had in my car to date!
IMHO unless running in a field of all cars of the same class and power levels, then just focus on improving your own times compared to own results.
Granted, with the DECA points scoring system it is a bit difficult to gauge how you went, since it's all placing and not time based. In that case use the seat of pants gauge or setup an in-car camera so you can measure your own times :P
What is your vehicle setup like if you don't mind me asking? Power/suspension mods?
Agreed, I try to gauge myself against similar cars :P
Have you tried clicking the tabs on the bottom of the worksheet? You can switch to the worksheets that show your times...
Greg - How were some of your results??! If you hadn't have buggered a few up you'd be right up the top mate, awesome job. 4th in the first Long Wang run is awesome. The old girl still has life in her yet :P
the old "if you didn't bugger up"
if only... but that's what deca is all about and it's great fun.
i was wrapped with some of the times considering the guy driving........ but a few little concentration lapse's is all it takes to throw a good time out the door, and as soon as you do slice some cones or wd there is always someone eagerly celebrating on the inside! :P
birds: car is fairly mild, and still used as daily commuter, 200kw and some jdm tein super streets, it has a few basic suspension arms too, but nothing over the top.
I need more grip!!!!
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
