hey guys
before you say, YES, i did do a search, found nothing to specifically help me.
i have a r32 gts-t and the seller, who was a chick mind you, told me its a rb25det engine, series 1 turbo. Now, i know a bit about it and i doubting weather or not it really is because its still a 2.0L 1998cc and only the rb20det came out like that, if it was the rb25 it would be 2.5L. Im pretty stumped so how can i find out what it actually is? Im not a pro at this kind of stuff but i do know a tad.
Also, if it is an after market turbo, not the stock rb20, how much would i look at if i wanted to remove it and how much effort. Being after market it shouldnt be too much right?
cheers
also im sorry if this is the wrong section, i couldnt find any other turbo related section.
https://www.sau.com.au/forums/topic/324487-removing-a-turbo/
I don't get it.
You say the seller told you it had an RB25 and you are saying it has a RB20 in it. So the seller lied to you or didn't know. I'm sorry I just don't get your question? Or do you not know what engine it is?
As for the turbo removal it isn't hard if you are handy with a spanner, why are you wanting to remove it though? You mean so you can change it for something else?
john post a photo of the engine bay
or pm a link to an engine bay photo
it will be the quickest way to work out what engine it has
and then for the turbo do the same
take a photo of the area and post it up or pm a link
there are obvious visual differences between the two (rb20det turbo and rb25det turbo) - regardless of what engine it is on, so it sohuld be easy to pick
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
