i would like 2 see more drift and Circuit;
In perth i don't really think there is anywhere 2 do the both on a weekly base. During the drag season evey wed night is open for street cars which i think is a really good idea, maybe we could get somelike that going for drift and circuit.
But then again i don't think any of that could not happen withone someone wanting to spouncers that type of stuff but i could be wrong
I was under the impression that there is a regular drift day at Qld raceway and isn't there at least one drift club in Bris? MRE where are you??.
I think the success of Power Cruise indicated one direction we'll be heading.
Drag Combat is back ....bigger and better.
The new AAA organisation will be making track days more frequent and more accessable eg at Qld this year...10 x Level 1 days and 10 x Level 2 days.
Apart from the distance involved nothing could be easier than getting on the track at Morgan Park.
In the more traditional scene there is a choice of Hillclimbs, Gymkanas, rallies, Khanocross,lap dashes etc every weekend.
BOOSTMEISTER ommitted one choice from his Poll...ie...All of the above. That would have been my choice
  • 4 months later...
/rant on
Please let it be circuit!!! The whole cruising up busy streets/drifting/neon lights blah blah is a load of BS. If ya got a wicked car and ya think ya got skills, take it to the track. There is no better place to test an all round car and all round driver. Any lame ass beatch can flick the ass out, power slide through a corner and chew up tyres.
/rant off
Just my opinion so dont flame me for havin it ;P
B
  • 5 months later...
The australian car scene needs some better direction and less wanky ricer mobiles out there being driven by people who think that because they have big rims and a stereo, that their car is a performance car, sports car, or luxury car. wrong. its just a big rice mobile. And to 3/4 of the luxury car owners, who drive their riced up cars like its a sports car - get a grip - you bought a luxury car, stop driving to be a boy racer.
here is a link to a site that is going to help shape the NEW aussie car scene!
http://thecarscene.com/
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
