Don't worry about what other people think. If YOU like the rims then you should buy them.
But since you asked.. they are close to the ugliest wheels I've ever seen.
+1
If I may offer a suggestion - if you want to go chrome maybe look at a more sporty design so you can have the best of both worlds and shut a lot of people like myself or xscape237 up :)
But yeah, go with what you like since it's your baby :D
https://www.sau.com.au/forums/topic/326076-like-these-rims/#findComment-5309487
those rims are giving me kebab cravings...
too dinner-plate for my liking.. but if your into sex-spec peripherals then get them...
That's a little unfair to kebabs, regardless of the positive correlation between one having chrome wheels and one's appetite for kebabs :)
https://www.sau.com.au/forums/topic/326076-like-these-rims/#findComment-5309792
How do those rims look good in any way shape or form? Their shocking to say the least.
If you really want chrome do as has been suggested and get a sporty looking design but then again for some reason you obviously like the dinner plate style so just go for what you want we can all snicker quietly. :)
https://www.sau.com.au/forums/topic/326076-like-these-rims/#findComment-5309825
When did chrome become such a fully sick thing? Don't y'all remember that Latinos and African Amercians have been having them for ages. By that logic, shouldn't people with loud sound systems be considered as fully sick with the doof doof sound?
I get ya don't like these rims, but most of y'all don't give any suggestions on Chrome that looks good, Help a brother out.
I get racing wheels, but which. help us out.
https://www.sau.com.au/forums/topic/326076-like-these-rims/#findComment-5311659
Yes, but the Latinos and African Americans do not put them on imported Japanese cars.
As a suggestion, have a look at the rims on my car. They are chrome. 19" with deep dish and staggered. They look fantastic IMHO. I have had lots of compliments on them, but I have also had some people on this forum say that they don't like them simply because they are chrome.
But you can definitely do chrome with style.
The poster above with the pic of the white sedan with the chrome rims. They look fantastic also.
Good luck with your search!!!
https://www.sau.com.au/forums/topic/326076-like-these-rims/#findComment-5311665
    • Saw this video today from Adam LZ.    Long story short is he is claiming that the load from the engine fan once the fan clutch heats up(engaged) is increasing the getrag rattle(at idle) when you don't have a dual mass flywheel.  Before I go buying an electric fan setup .... Anyone heard of this ?    I must admit when my car is cold the getrag is pretty quiet and I do notice the rattle after it is all warmed up. I've always assumed this is due to the gearbox oil temp and tolerances of metal.
    • Yep it sure does.   Tone wheel lines up in the same spot perfectly.
    • Something I meant to say when we were chatting the other night about having an open trailer floor being great to work on a car, but you've never used the feature... It's a great place to park a car after doing suspension component changes, and do the tightening of all the bushes with the car sitting at full ride height. Especially when you don't have a 4 post hoist!
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
