Hi All
I am new at the skyline scene, trying to gather enough info so i can make better decisions
below is my dyno graph, dyno was done on 24th june 2010, car has FMIC and pod filter, car has not been tuned since
i got it, no other mods are done, is this expected power ?? is it too low for a 1997 R33 GTS-T
what should be the next steps to achive my target power figure of 250 rwkw, an estimated cost
thank you
0681_001.pdf
https://www.sau.com.au/forums/topic/326222-r33-gts-t-what-next/
148kw is fairly ordinary from 8psi, check that you don't have a tiny compliance cat choking up the exhaust. Might be worth investing in a high flow catalytic converter, or a full turbo back exhaust (or a catback at least)
To chase 250kw, you are going to need to get a aftermarket ECU and get your stock turbo highflowed (then you can bump up the pressure, as you can't go higher than 10psi safely with the stock turbo wheels). Then to support 250kw, I don't think the stock injectors are up to the task, you will either need bigger injectors or a fuel pressure regulator to squeeze the most out of your existing injectors.
Power sounds right for factory exhaust.
Honestly - use the search function.
The ole "250rwkw - How do i get it" is a common common question.
From a bone stock car, to do it reliably with middle range parts you are looking @ $10,000 IMO.
Thats everything from better tyres, hi-flow turbo to exhaust & injectors.
the most rwkw you will achieve least expensively is around 170 - 180rwkw, once you get to this stage you need to start looking at turbos and injectors, ecu's etc witch is money money money.
youll get there with a 3"zorst and proper dumps/fronts, along with bumping the boost to 10-12psi (the most before you start having issues)
  • 3 weeks later...
See I'd say put the turbo in first, you want be able to boost it yet,which kind of defeats the purpose.
But at least then when you have your injectors and ecu the turbo is already done though...Thats how I did it anyway
IMO Its no use putting the ecu in first cause you,d have to get it tuned, and then pay to get it tuned again after your turbo which is wasted $$$..But putting a turbo in is pretty straight forward if its just a hi-flo, and even at 7psi will still pull harder than you are at 12psi now...
Edited by Arthur T3
Because a it's overated german shite IMHO
I know a guy with a 70s porsche with 700,000kms on it...original engine
if you spent 80k on a GTST and it didnt beat a porsche your doning something wrong lol
True, but ive seen people do it
Luckily i can wipe the floor with a Porsche then :thumbsup:
No doubt, but will your car pass a pit test??
My point is 80k will get you plenty of cars like an evo or better, that are ready to go...And just as fast as alot of these money pit skylines
Edited by Arthur T3
But it's better build quality :thumbsup:
And what's wrong with German precision?
M3s are no lame ducks either and then there are 335i with twin turbo.
Arguably nice cars!
The fun starts when you can smoke a Ferrari in the lower 12 sec range.
Edited by Torques
Well im doing 251kws on mine and i was required to do this:
ECU: Either a Nistune, PFC or VIPEC i choose PFC
Exhaust: 3inch all the way with a highflow cat
Cooler: return flow cooler
Turbo: Stock highflow with a .63 rear housing
Ignition: Splitfire coilpacks unless your factory ones are still good
induction: stock air box with a highflow panel filter or pody
Air flow: z32 or a Q45 i choose a z32
injection: i choose to highflow but i would recommend proper ones like nismo,sard 550cc's or so
fuel pump if your one is about to die, change it to a BOCH 040
do all of these and you'l be doing some good power on standard internals.
Hi!
Would you recommend a high flow turbo, or rather buy a 'proper' one?
Cheers,
Andrew
Highflows are great. Stock location, no exhaust modding. Come with everything you need to bolt it on.
Plus, all you aussies love it when it still looks factory cos your laws are a bit on the average side. Were heading that way at a guess too. So thats a big bonus in that respect.
I dont know what they go for new these days, but i dare say they would be cheaper than the Garret/HKS equivalents?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
