I saw this kit a while ago but what put me off was that you need to have the assembly balanced so more than just a bit of DIY is involved.
There is someone on the who is selling rebuilt stell wheel turbos for about $1250 exchange which also seemed reasonable.
I ended up buying some new Garretts but those guys on ebay had some good feedback. Let us know how it all goes. Would be very interested to find out results.
If it's too good to be true - It probably is.
Stay WELL clear of that.
Add to the fact you cannot just "bolt" it together. To be done properly you would need to have it balanced and so on adding on additional costs.
Meaning you might as well pay somewhere more reasonable to do it.
Add to the fact R32 N1's are horribly laggy turbos for bugger all power.
makes me laugh sometimes.... has anyone here actually rebuilt a turbo in their backyard without balancing and actually testing?
Balancing is overated.. whats the worste thats going to happen?
Try it. I have. One turbo i did is still alive on the car 6 years later. No balancing done at all.
Well I don't have any experience, but this is the interwebz so that wont stop me from shooting my mouth off.
Bearings chew out quickly and turbo dies
Sample size of one is statistically meaningless. The balancing process can merely involve verification and no actual modification.
Well your call but for the effort to R&R turbos on an RB26 I'd be using ball bearing bolt on ones . The reasons being that they are more reliable and longer lasting - often the wheels in them are later aero tech too . Don't forget with R32 GTRs Nissan was doing their R&D back in about 1988 and a LOT of water has been under the bridge turbo wise since then .
Yes the old N1's were really laggy and only seemed to work with the boost screwed right up .
Then when the old bush/plate thrust bearings lunch themselves , all that work and money to spend again .
Really I think the OE R34 BB turbos should be seen as a practical base line .
You time money patience , cheers A .
First of these are just steel wheels for the stock turbos, doesnt make them N1s.Second if the bearings already lasted almost 20 yrs whats to say new ones wont? So these will just be stock turbos with steel wheels which should spool the same and will have 360* thrust bearings and i also have a divided TT pipe to decrease spool time.
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
