hey guys i got a r32 and **** me u can hear the std bov a mile a way! I have a hks air filter and all the pressure is blown out throw that as there is nowhere else for it to go! sounds good!@not sure if the previous owner took the plumback bit off?
what would happen if u put a piece of woopy cushion over the end of the bov snout?? Hehehe imagin the noise hehe
The pipe i think your talking about is the one about an inch in diameter going down towards the turbo? Thats the recirculation pipe it goes back into the pipe from your air filter and is plumbed in just before the turbo. If you take this off youll have to modify your pipe from air filter to turbo, either getting stainless piping or patching the stock one.
S
Just get a pod filter and leave the plumb-back in place, the sound will be almost as loud.
Hehe, i think a kazoo or something would sound pretty funny too.
ok i tried this the other day and yeah the car runs heaps rich. I loved the sound but....the car wouldnt idle properly and stalled most times i came to a stop. HOWEVER if u disconnect the vacuum line going from the inlet manifold to ur BOV and block it off then..... insted of pshhhhht its "FLUTTER". Sounds amazing and the car runs a little richer but not really noticeable
What, the whoopie cushion idea? Or the kazoo idea?  :P
Check the net and you'll see its been done before, theres some movies around, I think it was some sort of Mazda, tried various things, eg baloons, party streamers etc, sounded quite funny. No link sorry, shouldn't be too hard to find...
Btw, my stock R32 GTSt bov is like twice as loud as the my GTS25t one, same filter too, dunno why that is...
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
