Hi all,
Just got my R32 tinting done at SOL-ACE and the guy there took 3 1/2 hours to do it and said that it was the worst job he's ever had to do! Turns out the rear windscreen has some very very thick demister lines all over it and these lines are raised which cause severe bubbling of the tint.
He had to individually cut around each demister line by hand/knife!!!!!! And even so the job is great but not 100% perfect.
So, be warned. I winder about all of you who do have tinting done on the rear windscreen... whether or not you have air bubbles all over due to these thick demister lines?
https://www.sau.com.au/forums/topic/32694-window-tinting-warning/
I've had previous R33s done and they didn't have that problem... Sure, there was a little air around each demister line when first put on, but they evaporated out with the rest of the little bubbles within a week or so...
No need to cut each line on my car...
we had a tint-a-car day group thingy in melb a while back and there was a couple 32's being done. the only real problem that they had was that the rear window was an aquard shape and curved quite alot around the corners....no talk about the dimister lines. i think it took them about 45 mins to do the whole car too not 3 hrs so i think the guy that did your car has never done a 32 before urs.
im not too sure about cuttin each line individually....have u checked to see if he accidentaly slipped and cut through one of ur dimister lines...id be worried about that.
Don't the skylines use that as an arial too? (thus the reason for it being thick) MY 34 already had the tinting when i got it and it wasn't bubbled but it could be stuck closer. The guy who tinted my front windows reckoned they should have done what your guy did justinfox but I think it looks alright as it is.
i got my windows done in october. I have noticed on 32's that on each of the front windows there is a blemish for about 150mm near the top of the window pointing upwards (sort of diagonally). mine has it and it annoys me, but i am not sure if there is anything that can be done about it....
Hi all,
If they had to do that... then i would be severly worried about thier abilities.
The de-mister lines in all sky's 31-33 that we had on the tint day here in Vic.
Not a problem.
The only problem that there was, as (B1) MR_fanny said.
We had the tint day down here in Vic.
Just the R32's bottom right/left corners was the slight problem to put tint on.
but they still got it done easily.
And this was 12 months ago, no-one has had problems that i know of
OK well the demister lines on a 32 GT-R may be different to some other models as for sure they are very thick and raised.
I have just gone down and patted each line down and it's perfect now in most places. Just a few little spots where I can see a little bit of air around each demister line.
The guys did not charge me anymore. They did an amazing job on my Alfa last time... so I know they're good. And the boss there was very very distressed about this job on the Skyline. He wants me to come back in on Tuesday next week so they can have a good look at it, see if they can smooth it all out until it's perfect. He wants to see it perfect... gave me a discount in any case too... which was cool.
Personally I am happy with it. I would prefer these minor imperfections rather than having no tint at all on the rear. I do have a 10yr warranty on the tint so if ever something went wrong in future I could get them to re-do the rear window tint.
Group buy last time with the other SAU guys with tint-a-car. No problem with the one R32 that was there, and the R33s there all went thru fine. Hrm, maybe they are using a different film. Sounds bizarre that only the R32 GTR would have different thickness demister lines.
there's spec differences in R32's some have a heavier demister line, esp later model ones. I have the same problem with mine, which is why I'm looking at getting a precut tint from japan for my R32. (yes you can actually buy tinting for an R32 precut for a 2 door or 4 door over the counter and do it yourself)
I had a guy do my Surf and Soarer in 20%. I had the Soarer done about a year later and when he got it he said how big the rear demister lines were and they had a build up of crap on them too.. He also had to use 2 sheets on the rear window as he didnt have any tint wide enough.
Anyway, 6 months later and i still cant find the cut line he did, and its sticking down really well. He also replaced driver side tint for $15 when i totally fkd it putting in a new window reg.
    • Hey crew, Failed my WOF cause of a lower control arm, and I've decided to hit both arms, and also the compression rods at the same time(seems they're gonna be the most likely upcoming failure points from some discussions with the lads over on the G35 reddit). I've looking at these form Z1:  https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-compression-rod-p-40716.html https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-lower-control-arm-p-40674.html I asked Z1 if they'd work as it's the same platform, just RHD vs LHD. I basically got told "Lol dunno". Specifically they aren't aware of any difference but can't guarantee fitment as they haven't done it on a 350GT. So guess I'm asking is if there is any issues with using 2005 G35 coupe suspension parts on a 2005 350GT coupe? Orginally I thought it could be something in the way of the arms that each control arm is designed to be positioned around, but that'd be an engineering nightmare for Nissan needing two different shaped control arms 😅
    • ^ This. The mode door actuator is a common failure, as is the actuator and/or the actual valve for the coolant flow control valve. I also don't know how available the mode door actuator is these days. I've been meaning to look into it and get one from wherever is possible, to keep in the shed for the rainy day when mine eventually fails. Anyway, the advice to you is to search the usual NOS part supply places, or even just go to Nissan and see what they list.
    • Have you got a pic of the actuator? My guess is that unit has failed internally and was flopping around, so the previous engineer who owned it forced it to be fully open to cold air (blocking the heater core path). As far as you can tell, is anything else wrong in the system? Likely you just need a new actuator (not sure how available they are) and then "installation is the reverse of disassembly"
    • I'm happy with the Lsailt unit that I put in, it puts full Android on the top screen so you can run whatever Nav and other Apps you want, while still existing inside the factory functionality like automatic reverse cams, audio input switching, retains factory bluetooth etc. Not cheap and the install was moderate (not simple, not hard) Yours is a V36 not V37 though right?
    • Yeap, all the NC's that I originally looked at that had a hard top were PRHT, which makes the roof line look horrible, hence why I said nope to them My only caveat for another MX5 was it needed to have a hard top, and initially I didn't think you could get a detachable hard top for the NC,  like my NB had Again, a big thanks to Matty for helping me source the detachable hard top for my little girl, they are as rare as hens teeth in Australia, and the few people who have them, keep them Also to Greg, for initially pointing me in the NC direction NC PRHT 🤢🤮 Not mine (I really should take more photos of my car), but a NC with the detachable hard top 😁 To me, the difference in how the detachable hard top roof line looks, and how it actually follows the bodies lines, like they do on NA's and NB's, is chalk and cheese compared to the bulbous looking PRHT
