  • Replies 165
You're in Wantirna yeah? If so I can get you man, it's not looking like I'll have a passenger.
EDIT: Man, if I hear Inception being advertised once more on the radio I'm going to f***ing scream. It's ruining the movie for me. And /b/ already ruined the movie for me.
cheers man. i'll give u a text early tomorrow and let u kno.
late notice i know but i could also potentially be in for this... just need to wrangle some mates to fill the car up a bit. dont put me on the list but if i just rock up at the car wash would there be any problems with that?
Don't worry I too have jap speakers and apparently its in the range
Jap radio u mean ya?...ya usually it is but sometimes its just outside the range..lyk the one near my house, 2 out of the 3 screens are in range..so hope so bro
I'll be lol'in at you both if you cant tune in muhahahahha :)
dont u dare even think of laughing bro....you wont get that video off me if you do...think about it...LOL...
My stereo is loud enough for a couple of cars either side :)
well ill just make sure i park my car next to yours then just in case....LOL...
PLEASE HOPE ITS IN RANGE!!!!!
o0o0o might make it to this :)
Edit.. f*k it im there count me in ..
Guys, your more then welcome to come down.
For everyone that is coming the manager gave me a final call today to make sure we definitely have the minimum 20 cars and I said we did so all is well, more is fine.
Now going to spend 3 hours washing/cleaning the car tomorrow :)
Oh, and just so we can clear this up:
All their stations are within the mid 90's so its fine.
It's funny to see how many people are as lazy as me with their radio :D Who listens to radio anyway?
Get This FTW! Oh wait....
Screw you Pete and Myf!!!
RIP Armitage Shanks.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
