ok, i suppose i will give it a shot, if it will help with coming on boost earlier.
i was just more concerened about it casuing damage if not done with any other appropriate mods,
as far as i understand it'll have bad effects on the turbo causing early failure............
https://www.sau.com.au/forums/topic/327936-m35-bov/page/4/#findComment-6156734
The bov still works fine with the grub screw in, all its doing is bypassing air back to the intake so there isnt a huge pressure differential when the bov opens. My car ran fine with it plugged, it also held boost better and this would help the turbo last by bringing shaft speeds down. Why compress all that air then bleed it off if you dont have to, especially if you are trying to hold over 20psi.
Just run a 5mm tap into the 4mm hole and stick a grub screw into it. :thumbsup:
(Wont fix farting noises, that would be either BOV piston seal or manifold to turbo gasket most probably)
https://www.sau.com.au/forums/topic/327936-m35-bov/page/4/#findComment-6157292
If you had some way of tuning the ecu you could try and take out the fuel dump when the bov opens, I think the Emanage can do that to some extent, otherwise no, the air is metered and needs to remain in the system.
Realistically any car with airflow meters can't run atmo, only map sensored cars can which is why the epa made it illegal.
https://www.sau.com.au/forums/topic/327936-m35-bov/page/4/#findComment-6158865
I'm running Aaron's Turbosmart Kompact with the stiff spring at the moment, its quite snappy when backing off but feels good none the less. The stock one was working fine with the grub screw mod but it could be due to the tune.
I ran 19psi on the stock turbo for 4 or 5 months, don't do it unless you are prepared to replace the turbo obviously, although I have a spare here. :whistling:
To run high boost on the stock turbo, or any highflow version of it, you will need one of my modified actuators. That should hold around 15psi and allow over 22psi with a controller. Without the stiffer actuator it wont hold more than 14psi in the top end.
https://www.sau.com.au/forums/topic/327936-m35-bov/page/4/#findComment-6159967
  • 3 months later...
Has anyone actually figured out if this is a BOV problem?
I still have the exact same issue, and Im confident its something to do with the wastegate as you can hear it reverberate right through the exhaust. It literally sounds like its underneath you when driving. If you hold the throttle right when it happens you can make it fart as long as you want. I tried blocking my BOV and still had farts.
To me it sounds like the wastegate isn't opening properly or shuddering. It only farts under medium load. If i floor it it cannot fart - its like it opens properly then, but if im building boost up a hill slowly it happens most of the time....
Surely if it was BOV it would still fart when I floor it. It would fart at the same boost level everytime?
I want to fix this as it shits me!
Benny,
Did you get this sorted, your description is much closer to what my car is doing. Wastegate or BOV?
Chris
https://www.sau.com.au/forums/topic/327936-m35-bov/page/4/#findComment-6295683
  • 3 weeks later...
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
