Hey all,
Will be building up my RB25 R33 for approx. 500rwhp around April 2011, and need to know a few things before I start..
Background - the motor currently has stage 1 HKS cams and exhaust cam gear (adjustable), however I am unsure of the timing as the motor was bought secondhand.. i assume around 262-264 possibly? also has ACL forged standard bore pistons, and race bearings all round. running on standard conrods at the moment.
New parts - Will be upgrading with the following: Garrett GT3582R .67 rear (700hp capable), 750CC injectors, Sard fuel rail, Malpassi rising rate FPR, walbro intank pump, high mount manifold, plazmaman front facing plenum, and Link G4 plug-in ECU.
I'm shooting for 500hp, so using the rate of approximately 20% loss through a manual drivetrain that puts engine/flywheel power at 600hp...
I want to know if anyone here has ever run an RB25 on this sort of power, I assume it'll need to be running between 22-30 psi of boost, but this will only be for a dyno run to prove capability, the engine will be down-tuned to around 300rwkw or approx. 400rwhp for daily use.
Also if anyone knows, what is the approximate breaking/failure point of standard Nissan conrods in an RB25? I know I'll probably need to upgrade them in the near future anyway, but I understand that dyno-runs at 500hp and daily driving at 400hp exert different stresses on the motor (dyno offers a lot less friction so bigger numbers are easier to obtain without overly much damage to the motor).
TL:DR; will 500hp dynoed and 400hp daily tune kill my standard RB25 rods? pistons are forged.
https://www.sau.com.au/forums/topic/328015-rb25-bottom-end-query/
Garrett GT3582R .67 rear (700hp capable) - i wasnt aware garrett made any other than .63 .82 1.06 genuine T3 housings of which the .63 will be hard pressed to make more than 350kw @ the rears, if you want the power go the .82 or 1.06
walbro intank pump - i would be looking at a bosch 044 instead they are proven time and again that they can pull the numbers
I'm shooting for 500hp, so using the rate of approximately 20% loss through a manual drivetrain that puts engine/flywheel power at 600hp... - at the best of times guessing these figures is akin to picking the lotto numbers, if you want to know what it has at the fly get it on an engine dyno.
I want to know if anyone here has ever run an RB25 on this sort of power, I assume it'll need to be running between 22-30 psi of boost, but this will only be for a dyno run to prove capability, the engine will be down-tuned to around 300rwkw or approx. 400rwhp for daily use. - nytsky has 400kw with a built 25, you build the engine to take this power, with the lag of a turbo that will make the power, why wind down the boost like a girly man :wub:
Also if anyone knows, what is the approximate breaking/failure point of standard Nissan conrods in an RB25? I know I'll probably need to upgrade them in the near future anyway, but I understand that dyno-runs at 500hp and daily driving at 400hp exert different stresses on the motor (dyno offers a lot less friction so bigger numbers are easier to obtain without overly much damage to the motor). - Rod bolts are the weakest link more so than the rods, if you can just open it up and get some spool rods fitted $600 + fitting, a small price to pay for security seeing as the rest of it is already done.
TL:DR; will 500hp dynoed and 400hp daily tune kill my standard RB25 rods? pistons are forged. - TL:DR maybe, it may last for years or it may not, you may win lotto tomorrow or you may not end of the day its luck and tuning
I think you'll find a legitimate 500rwhp a bit hard with a .67 rear... you sure that is correct?
The only other thing is the factory rods - Totally depends on what rod bolts were used.
If for some reason factory items were installed - you would want to think twice about it all TBH and settle for a bit less power/smaller turbo to be in the safe side
Otherwise mirror what Titan has said, especially the fuel pump part.
thanks for all the help guys, sorry I did actualy get the A/R wrong on the rear I had a different turbo in mind (or had a fk up, either or it's my bad!)
I was talking to a mate, and for the sake of an extra $1500-$2000 it may well be worth looking into getting some decent forged I-beams and fitting them up, a friend in town is a qualified mechanic who's doing weekend cashies, has built an RB25 and a 25/30 from the ground up with pretty high power so I figure i'll talk to him to get some forged rods and ARP rod bolts, all the bearings are ACL bearings, the motor is pretty well nearly built for that sort of power as it is, the only weak link would be the rods and possibly it would be worth looking into flowing the head a bit better, i mean im spending close to $10k as it is on just parts and tuning so why not spend a few hundred extra for some head goodies while the head is off?
i figure with an AVC-R and a decent cam duration it wouldn't have too much trouble building boost, especially when i get bored and turn on antilag =P
NB: current parts list, edit and add others if you see the need or if i've missed something =D
Garrett GT3582 - 0.82 rear
Wastegate - Tial Sport 38mm
Turbo Manifold (high mount)
Plazmaman intake manifold kit (piping/plenum/silicone/bigger tb)
Fuel System Upgrade - Bosch 044/750CC injectors/Sard rail/Malpassi FPR)
APEXI AVC-R boost controller
Link G4 Plug-In ECU
Spool Conrods
ARP Rod Bolts
I figure if I go with forged conrods it probably means I can crank maximum recommended boost out of that turbo and aim for over 500rwhp, as I said it'll be getting down-tuned for street duties (cops are arseholes in Toowoomba/i'm a poor uni student and need something reliable-ish)
All help is immensely appreciated
Link G4 Plug-In ECU
Spool Conrods
ARP Rod Bolts
Intank Bosch is 040. Shouldn't need fpr or new fuel rail (unless you're getting some odd-ball injectors).
you could sell off the AVC-R and use the built in boost control with the ECU, with a wired in switch you can have dual boost settings, but with a motor built like that the power isnt going to hurt it.
Just leave the boost up and dont put your foot down as far you get the same result.
make sure you have a 044 pump and your turbo has the 1.06 rear housing for that horse power. as well as the rods issue and no more then 7500rpm it will live a long time
I was always led to believe that the .84/86 was the one to go for for 500-550hp? I thought 1.06 was only if you wanted 600+? and had the luxury of more displacement.
P.s what would the lag of a 1.06 be like on a 2.5ltr considering the .84/86 wont be on full song till the early (if your lucky) to late 4000rpms?
The GT35 is a 700hp rated item in the .82 IIRC
I know my GT3040 was 600hp in a .82 with the largest GT comp wheel on offer (and was well and truly on song by 4k rpm)
Given it was what, 17psi for 270rwkw with a crap exhaust, so give it 20-22psi 300-320 is what you'd expect from the 600hp variant without much of a worry (in theory)
I cannot see why a GT35 with a 82 couldn't see 350-360rwkw with 22psi or so given it's a proper external setup and if the motor is build right.
With a Garret-IW you might have problems however but that's not something to deal with in this scenario
it's going from side feed standard injectors to top feed 750cc's so i thought i'd need a rail?
would a TR44 wheel from that mob in brissy be even worth looking at out of curiosity? and i'd rather the 0.86, ill talk to a friend down here who made 472rwhp with the gt3582 and see what housing he had..
i don't want an overly large lag, like i understand im gonna have to expect some going from a highflowed standard turbo being on full by around 2000rpm lol... i'd honestly be happy with 480rwhp (360rwkw), it's still a pretty decent power figure, in the end of the day like i said, will be tuned for daily driving, the dyno sheet will basically just be a wank sheet when i do sell it (trust me, I will eventually!)
QUOTE (KiwiRS4T @ 9 Jul 2010, 03:53 AM) *
another thing i'm curious about is cam timing, i know i have got some form of cam replacing the standard but i have no clue what size, like i said the engine has been replaced and it came as is, the mechanic who built it doesn't know the timing as the cams were done with tuning, im guessing 256deg... i was thinking of up-rating the entire valvetrain anyway, tomei all through so valve spring seat shims, solid lifters and a big lift/big duration cam (270deg).. would 270 degrees be too long on the exhaust timing as well as intake timing?
Edited by fattox33
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
