i wouldn't buy any GTR for 10K! most likely it'll leave you disappointed as you'll probably need to sink big dollars into it just to get it going properly! most guys i know who own R32's eventually put the R33 motor and gearbox into them anyway! if it was me, i'd go the R33, but i am biased. however you cant ignore the fact of the much better, stronger and more reliable motor and gearbox the R33 has compared to the R32. the R33 also has bigger brakes (same as R32 GTR) which also makes a big difference.
Who would that be Luke? :D
Nothing beats an R32 GTST with R33 running gear for super fun happy driving enjoyment - Lighter than an R33 GTST with the extra torque and power of the 2.5L engine and a MUCH stronger box and a better chassis (in my opinion) meaning better handling.
  • Replies 81
Who would that be Luke? :blink:
also looks better and wont attract harpoons :P
^^^Ha........and all the things that add that weight are the very things R32 owners envy, bigger motor, better brakes, newer interior, extra leg room etc etc etc all add just a little bit of wieght but make a car not a billy cart!
No I think he wants an R32, he's into old cars............he wants one he can cut the rust out and restore!!!!
An r33 won't do it for him, too new and no rust.
rofl
How long can you wait to save an extra $3K for a stock R34 GT-T (circa 1998) like Andrew mentioned?
I'm not being a nit picker or anything :/
RB20's are stronger but older, also RB25's are lighter, gearbox is the same weight, and almost all 32 are type M's, so the calipers are the same weight. So the weight is in nothing we envy. Interior is newer but less huggy, you sit less in the car and more on it and what extra leg room, marginal in the back, but the front is the same
Quick Pro's and Cons
R32
+Chassis, Price, Weight, Smaller Size, Nimbleness, better suspension standard, Drivers Skyline, RB20 revability and strength, reliable if looked after well, boot space, sit in not on
-Age, lack of reliabilty if not looked after, RB20's lack of torque, High KM's,
Note 20 Gearbox aren't that weak, RB25 gearbox stronger though
R33
+Extra torque and Power, bigger car, more aftermarket support, Price, Newer
-Chassis, weight, Larger car, Need to spend more money on making them handle, Don't like to rev, Sit on not in, boot space
R34
+No bigger than 33, better Chassis than 33, newer, more refined, More power again (not buy much) looks, low KM's
-Price, Still heavy compared to 32, Still don't like to rev
25 boxs are actually 20kgs heavier. by the time you do the 25 conversion in the 32, you're not that far off a 33.
33s by the by also have better suspension geometry than the 32, same setup , just more refined.
31s are what you're after but... :/
I'm bored at work, so I'm gonna pick apart Reece's argument :/
The R32 gearbox is the same as the R31 box and yes, its not a weak box, but it is not strong either (I define a weak gearbox as the S15 6 speed). Give it some bad treatment and it wont last very long. The R33 gearbox is a big improvement over the old one and it will definately handle more punishment than its predecessor. Its what a lot of people use for moderately powered (400kw) RWD RB26 conversions. I read line that in an old HPI once, so there :D Another good argument for them is that mine is still going as strong as ever after all the skid pan and trackdays that i've done over the years! I'm surprised that you didn't mention the better diff that the R32 has....
You've listed price as a negative for the R34. I dont agree. For about $8000 you can get a fairly nice, stockish R32. For an R33 your looking at about $10,000 for a good one and for an R34 your looking at about $12,000 for a good stock one if you look around a bit. A difference of $4000 isn't that big of a gap for a much newer and better all round car. Saving money harder or for a little longer would be well worth it.
I reckon the R33 handles better than the R32 in stock form. I also reckon you dont need to spend more money on handling if you own an R33. For the same money you can get nearly the same parts for both models. Most coilovers are put into the same category by manufacturers, therefore making the price nearly the same. Also springs and shocks are pretty close too. If there is a difference in price, it wont be a big one. Of course feel free to correct me if I'm way off!
And the difference in weight isn't as big as everyone is making out to be. Its around the 150Kg mark give or take, which in terms of street cars isn't a huge difference. You wont notice it when driving around town. You might notice it at Wakefield Park after you've spent some money on the suspension along with good tyres and brakes. Even then, unless your doing 1.12's or less, you still wont notice a huge difference...
OK, moving away from there now, something else to think about with the R34 is the turbo. The R32 and R33 use a ceramic wheel turbo and can be boosted higher and more easily. The R34 uses a nylon wheel turbo which is much weaker than the others and can't be boosted without running into big problems. DriftGTS had an R34 turbo on his RB20 for a short while. He ran it at 10psi for about 4 weeks before completely destroying it! Yes he gave it a hard time, but it still would have happened sooner rather than later. I've been running 11psi on my standard R33 turbo for about 2 years now and its still going strong.
My 2 cents... Again! :) Yes I am bored...
now im going to pick on lukes a bit.
really only around 50kgs between the models, dont forget to add 20kgs for autos and 20kg+ for sedans
1992 R32 GTSt = 1320kg
1997 R33 GTS25t = 1370kg
2000 R34 GT-t = 1410kg
the34 turbo was going good for around a year at 11psi, only let go after snapping (and i mean snapping) 2nd with semi's. + i got it for a case of coke'a'cola as it was on its way out.
with the extra 30kw and 30nm between 32 and 33 (flywheel) and extra 100mm wheelbase you wouldn't notice the difference in weight, as luke said
why not a 32 gtr. might have a few kms on it so you better change the oil pump! but better then any gtst or gtt will every be! then you can save some money and build a monster...
I have to disagree with that... I have driven multiple GTR's and GTST's in the recent past and have found that you can have just as much fun (if not more) in an R32 GTS-T after spending far less money on it than if you were to get a GTR...
R32 GTR's are getting long in the tooth now and they have a lot more that can go wrong, meaning that there are more parts to replace when they wear out and they are more expensive when you do replace them.
Don't get me wrong, I love R32 GTR's (they're still my favourite) but you need deep pockets to own one these days (just ask GTRKat) :D
your just soft!! GTR always wins. its like an omega commonwhore vs a clubsport r8 :kiss:
Says the man who never drives his Supra... :D
The main thing everyone forgets about GTRs and R32s in particular. Sure the purchase price is cheap but many people can't afford the maintenance on them. If they're original turbos they're generally not far away from going, suspension is usually f**ked too.
I'm in the progress of turning mine into a monster but it can be slow progress depending on what your line of work is and what other expenses you have!
At the end of the day, it all depends on what the guy wants to buy! Maybe like many of us 32's are his favourite? Of course there's pros and cons to all of them.
My pinky (33) is loverly.... Mind you I saw a nice R32 painted in Champagne (lexus gold) with an RB30 n it for $13k.... I would go there... If I could afford that and Pinky :D *Mmmmmm daydreams about being able to afford both girls*
*Tis Melly*
I apologise for my error and I hope that you can find it in your heart to forgive this mis-information... :whistling:
Basically all the info I've heard about the R34 turbo is that it breaks more easily than its older sibblings when boosted. Probably helped if I actually spoke to an R34 owner! :teehee: But I guess a big part of it comes down to how it has been treated over its life...
    • I see you've never had to push start your own car... You could save some weight right now...
    • Sounds good.  I don't 100% understand what your getting at here. When you say, "I keep seeing YouTube videos where people have new paint and primer land on the old clearcoat that isn't even dulled down" do you mean this - there is a panel with factory paint, without any prep work, they paint the entire panel with primer, then colour then clear?  If that's what you mean, sure it will "stick" for a year, 2 years, maybe 3 years? Who knows. But at some stage it will flake off and when it does it's going to come off in huge chunks and look horrific.  Of course read your technical data sheet for your paint, but generally speaking, you can apply primer to a scuffed/prepped clear coat. Generally speaking, I wouldn't do this. I would scuff/prep the clear and then lay colour then clear. Adding the primer to these steps just adds cost and time. It will stick to the clear coat provided it has been appropriately scuffed/prepped first.  When you say, "but the new paint is landing on the old clearcoat" I am imagining someone not masking up the car and just letting overspray go wherever it wants. Surely this isn't what you mean?  So I'll assume the following scenario - there is a small scratch. The person manages to somehow fill the scratch and now has a perfectly flat surface. They then spray colour and clear over this small masked off section of the car. Is this what you mean? If this is the case, yes the new paint will eventually flake off in X number of years time.  The easy solution is to scuff/prep all of the paint that hasn't been masked off in the repair area then lay the paint.  So you want to prep the surface, lay primer, then lay filler, then lay primer, then colour, then clear?  Life seems so much simpler if you prep, fill, primer, colour then clear.  There are very few reasons to go to bare metal. Chasing rust is a good example of why you'd go to bare metal.  A simple dent, there is no way in hell I'm going to bare metal for that repair. I've got enough on my plate without creating extra work for myself lol.
    • Hi, Got the membership renewal email but haven't acted yet.  I need to change my address first. So if somebody can email me so I can change it that would be good.
    • Bit of a similar question, apprently with epoxy primer you can just sand the panel to 240 grit then apply it and put body filler on top. So does that basically mean you almost never have to go to bare metal for simple dents?
