Not sure if this has been discussed on here, but I came across this a couple of weeks ago: http://www.autoblog.com/2010/01/12/rumormi...rged-2-5-liter/
It is rumored that the 2011 Nissan Infiniti will be released in a 2.5l turbo variant using the VQ25DET like that in our M35's.
It would be awesome if we saw some aftermarket parts produced in the US.
https://www.sau.com.au/forums/topic/328759-2011-infiniti-to-use-a-vq25det/
Lol at the comments, (Quote: 20 min, and a $500 chip flash later, Chances are you can gain an extra 50-75 hp and torque.) Yeh right, I wish. :D
If only they knew our beast is easily good for double the stock power.
And it has the Maxima (2010) wheels I like, they are 19"s x 8's or something on the maxima but they will probably be staggered on the infinity.
but how much is too much...and who will find out first.....me thinks you atm!
WE will still be lost though because our cars run a Jap only OBD whereas Infiniti will run OBD2 or whatever they use for export cars. I'm guessing it will work with ours but may need a whole loom and ecu swap? Maybe just an ecu swap IF all the pins are the same. COBB accessport will probably work with these.
Lol at the comments, (Quote: 20 min, and a $500 chip flash later, Chances are you can gain an extra 50-75 hp and torque.) Yeh right, I wish. :thumbsup:
I read before that the US were getting 1000 HP out of the R35.
and what makes you guys think that it will be a VQ25det?
Nissan canned that engine 6 years ago due to being unable to meet emissions requirements.
Whilst it would be awesome if it was the same engine as ours, I would think it would be safer to assume that it would be a high comp, low boost version of the VQ25HR would be more likely... IF it actually happens.
Yes only proper turbo petrol engine (factory fited) in a Nissan vehicle anywhere in the world is the 3.8 GT-R motor...
Unless they are looking at the 0.7 turbo, 1.6 turbo, or even the 1.2 3 cylinder supercharged motor in the new Micra...
Seems more likely to be the 2.5 Direct Injection motor similar to the one in the Maxima..
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
