My new bus. About to get rego after bringing it back with me from my holiday
Engine Bay
As we drove out of Zurich on the way to Stelvio stopped by this lake for a few pics
Had to get a photo of it in a Texaco service station
In the car park at Spa...parked near other 80s tragedy so snapped a pic
Half way up the back way to the top of Stelvio Pass
Top of Stelvio Pass
Going back down Stelvio Pass in the Italian Alps
Another part of the Alps, Flüela Pass
At Nurburgring
And when you are on an autobahn outside of Stuggart, make sure you go the wick turned up:)
Needs rear pods... *points to my sale thread*
yeh wrong colour though, cbf painting. I've had a lip spoiler sitting in my garage for a couple of months that I havnt bothered to paint yet.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
