I dont think Google images does it justice. But I from what I saw id still prefer the midnight purple
To keep this on topic.
http://www.skylinesaustralia.com/forums/topic/130489-post-up-your-r33/page-241
sun glared pic, but I have trouble with my suspension.... any ideas?
Yeah, connect the struts up to the knuckle and take all the bricks out of the boot... It looks like it should have VN stockies on the back end with that fitment :P
haha :P
despite tucking more on the rear it sits level, like most cars the rear arches are smaller
That's really nice for $500. Wish my $500 31 was that nice. But, you know, cars and concrete car park poles don't mix together really well. Especially in reverse.
  • 3 weeks later...
hey folks, Throwing up a few pictures of my r34 gtt.
I am moving down in a few days but my car is staying here until it gets out of the panel shop.
Hopefully me and my girlfriend will have our own place by that time as well.
My lmgt4's just after getting them
A quick photo just before putting it on a truck to the panel beaters.
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
