  • 3 weeks later...
  • 3 weeks later...
froth'n
^^ Bags or Static?
Did you end up going Super or Turbo Charged?
Bags all 'round. Ended up going supercharger and happily sitting on 400rwkw @ 10psi with close to 1200N/m of torque :cheers:
Edited by T.D
  • Like 2
How much for the charger kit and whatever else you needed to do?
For the charger, injectors, fuel pump, fitting + tune worked out to be about $12k. Camshaft, valve springs, pushrods etc. was about $3k.
