lel yeah mums had one of them since new, lots of power down low but tapers off hard
very nice car though, especially for 2005 interior is great
Edited by UNR33L
(dont quote me on this, but) I think its a computer/viscous controlled setup that activates the rear wheels (up to 50% of power) only when the front wheels lose grip.
Remove computer, leave viscous. BOOM subi/emo rival.
  • 3 months later...
  • 2 months later...
  • 1 month later...
  • 3 weeks later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
