Anyone know of any good guard rolling services out in the Eastern suburbs...preferably Bayswater/Kilsyth area?
I would prefer the kind who can come to you as I would rather it done onsite at my workshop. Price isn't a major issue, I'm more after a job well done.
Cheers in advance.
https://www.sau.com.au/forums/topic/330489-guard-rollers-in-eastern-suburbs/
I trust Hamish with my food, I don't trust him with my guards :D
Anyone have Athid's contact number? I no have facebook :blink:
I've got a guard roller but I'll be damned if I trust myself to do it properly.
EDIT: All good, found it: http://www.skylinesaustralia.com/forums/180athid-m6642.html :)
Thanks all!
oooo can i borrow your gaurd roller.... need to roll the rear gaurds on my gazelle.... infact .... would you like to practice on my gazelle ?
... then you'll be a pro and can do it yourself!!!
on that not, sorry to hijack your thread, but anyone who has a gaurd roller is welcome to practice on my gazelle if they like, i need them done, and i dont care how good the result! i really dont care!
athid is the best man for the job, but as stated is in Vegas for Trent's wedding ATM
I cant do yours as my roller is broken at the moment ;)
dan from ADM will probably come to you and is located in ashburton... pm me if you want his details
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
    • There is a warning that "this thread is super old" but they ignore that anyway...
    • With 10% Ethanol, we're talking 2-3% fuel consumption difference. The emissions reductions and octane boost in my opinion far outweigh this almost non existent loss.    My tanks sitting at 80%. Luckily that should go down fast as I'm on vacation again for the next two weeks.
