No, just killed response of the setup :) From what i read and was told was expecting a 200-300rpm improvement in response, not drop off. Oh well, will be interesting to see if it drives any different, but not encouraging that seems to lag behind orginal Greddy manifold. Maybe i should rip all this shit off and not mess with something 'that aint broke'
Lets hope its something like a restriction with plumbing the gate back in, shitty spring and opening of gate too soon, crappy BOVs or a leak somewhere. Lets hope
checked compression after the few years of abuse and sitting gathering dust, maybe the little 20 is flogged out?
Well after a weekend of driving around DECA there is nothing wrong with the engine. Plenty of head scratching has revealed there are a few little tweaks in teh setup that we will try whcih will improve things. Need to run it again onm the dyno with 17" wheels and find some Shell 100 equivelant fuel as my last tune I am comapring the current one too was on 100 and took a lot more ignition. Will also try dumping the plumb back to see if we find some more top end with an open gate exhaust.
So, at a minumum there is no performance improvement from changing to the 6boost manifold. But it seems that there isnt the loss in performance that I first feared.
So engine is still fine, even after some 8,400rpm limiter work on the skidpan. I think it will need the 25G to break this engine....but no way I am going to give that a try considering that all the changes have netted nothing in the way of improved performance, only hopefully reliability looking forward.
Yes, without the titanium exhaust on the car the whole plumb back thing has left me feeling a little empty inside :P
So, below is the plot. The changes are:
Old Tune-Setup
100RON Shell Racing
HKS Type S Cooler
Greddy manifold and Type R gate
3" dump pipe and atmo gate. 3" straight pipe for cat on dyno (to eliminate the cat as a power killer during tuning)
NewTune-Setup
98RON Shell
ARC 100mm GTR Cooler
6boost manifold and Turbosmart Hyper Gate 45
3" off turbo into 3.5" dump with plumb back gate. 3.5" straight pipe for cat on dyno (to eliminate the cat as a power killer during tuning)
So you can see there is a dramatic change in response which seems to be mirrored in the power the thing makes. We are reving it 500rpm harder, but even still there is a possibility that we have changed the final gearing by running different size wheels/tyres. But we dont think thats the case, but will trial a few things here as well
So will throw on the SBC ID and see if an EBC can do a bit more for response. Open up the gate to see if its hurting top end. Throw some RON100 in it and there are also a few other things I want to try before throwing the 256/8.5 Poncams and Plazmaman Plenum on
That's what it looks like to me, a little later on the power and a little later making peak power...
I would also assume the extra timing used with the 100RON fuel would have made you able to smash more timing in the mid range and create better response :ermm:
Roy what have you done!
better spending the money on the chassis to get it handling really well IMO... your engine/turbo setup was never an issue was it?
I wanted to fix some of the piping around the turbo outlet etc, and the Greddy manifold was getting old ad everyone pulles their d1cks about how the 6boost manifold would perform better then even a Greddy manifold. So the idea ticked enough boxes ...and the main thing is the 6boost manifold should work well for a number of years.
I think I have gone as far as I want with suspension, thought about all those funny doo-dah arms, but honestly, it would be prety easy to go backwards and dont want to pay 2k in labour for fitting and a wheel alignment. Does need to be lowered a bit more and then I will try to get a better alignment into it.
Plus, I was hoping to go 25G and have a +300rwkw stock RB20 :) But think that setup will have to wait for the built motor
Roy, just for interest sake, I pulled the engine out of mine last night after I boiled the oil at Lakeside and did a big end, and she looks pretty good!
#4 big end looks to have failed, giving enough bearing play to break the piston oil squirter off.
Crank/rods look good as gold. Compression is a little jumbled though, with mins and maxs differing about 15% instead of the 10% that I normally abide by.
Gonna give her a full birthday though, just wish the rules would allow some more freedoms to run one of your turbs! :D
This car has too much history, would never part with it Troy if I were you.
Remember the very first time I saw it at a Winton fun day many moons ago....
It hitched a ride with me back to Melbourne, didn't look healthy at all...
Ahhhh the memories....
Very much look forward to seeing it back out at the track, can expect some very decent times.... for a RWD.... :thumbsup:
C'mon!!! Get it back out there!!!!
LOL, ahh that was a funny day. You and Geoff really helped me out of a bind! Its funny. I look at those pics and I honestly think it looked better with those wheels, factory paint and bodykit then it does now :thumbsup: What do they say about dont fix what aint broke! LOL, though I suppose it was broke :blink:
And it will be back on track soon Jack, early October actually. But before then I need to get some practice, so next month doing a track day at Silverstone, two days at Nurburgring and a day at Spa. Should get my eye back in :D
Don't be hard on yourself mate, it looks HORN at the moment.
Practicing at some of the worlds best tracks??? Can't beat that.
Give us a hoy when you're back in town....
  • 1 month later...
Well I am now back in Aus. So this weekend will be getting RE55s fitted to my TE37s, checking the brake clearance for the brake setup and also finally getting around to prepping my new rocker covers. While swapping the rocker covers will try the new plenum and baby cams
Edited by Roy
    • sold listed as a Tomei LSD 1.5 Way For 1998+ Nissan Skyline ER34 25GT RB25DE w/Open R200 https://www.ebay.com/itm/174006114594?campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=&mkrid=711-53200-19255-0&loc_physical_ms=108689&loc_interest_ms=&campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=71883f2ccc571356e0a757bc7adfdde2&mkrid=710-53481-19255-0&loc_physical_ms=108689&loc_interest_ms= it went in like butter all gears, alignment, back lash etc, rotation and clearances correct, and if rolling all rotates smooth and free when coasting down road , clutch in or out over 10 mph smooth... its the binding, clunking and jerking from a stop that is most concerning, also seems like its going to tear the tires off in 10 miles of normal road driving.
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
