I am waiting to see what tax man has in store for me this year after years of being severelly anally raped by him. I would like to make the most of the next few track days with the RB20 making the power it is so will hold off until i have some AO50s. That was if the engine pops then I at least had a chance of getting the most out of the setup with a std RB20...as the next step will be stroked goodness with billet bits, multi throttle inlet and 6 speed :)
Haha I quickly did my tax yesterday... $1.73 credit, was raging hard.
  • 1 month later...
  • 3 months later...
It still has a 20G on it at the moment but have a billet TD06L2 to try when I can get around to installing it and the tuner is a little bit quieter. Racepace are pretty busy with preparing some World Time Attack entered cars so don't want to bother him with tuning my thing until he has had a breather
so how's this going?
ps happy birthday for last week.
Nothing is going for the lil R32 at the moment. A hose under the inlet manifold let go in traffic and I cooked the engine :( Damn peak hour traffic and a55holes who think you are just lane hopping and not trying to pull off main road to save killing an engine :(
So its got a leak head gasket in No.3 or 4...cant remember which cylinder came up as the problem. Still making good power and still driving it daily...its just that it is pressuring the coolant system and missing pretty bad at idle. New engine will heopfully be in around Aus day after engine bay is sprayed and then throwing the 10cm housing on the thing, with Tomei 256 cams and back to back the billet 73HTA and Greddy 20G. Other delay was the R34 6spd that I had stripped for refresh before putting in came back needing a few too many little bits to be like new so going with the trusty R33 5 spd I hae had for years as back. up. Mega gutted that the 6 spd didnt work out...
And thanks...I feel 6 years older, not just one :(
  • 1 month later...
Well after abusy few months with a new job/project and slowly re-wiring the Sierra and rebuilding its engine...I put it aside to do a few weeks of rather intense work on teh old R32. Its now just about ready for a full years of track duties.
So did some re-wiring. Re-sprayed the engine bay....did a load of other minor tweaks...and then put the 20G backl on for the first round of back to back tests provided the new engine isnt a shitter and craps itself on run in :)
The new heart
Re-sprayed and DEI'd up engine bay
Sitting in the tarted up engine bay
Tucked away in the corner with her older sister until I get back from Portugal in a few weeks
The new heart
what mods do you do to teh engine?
did you shave the head?
take the valves out and get rid of the over casting around the valve seat?
stock oil pump?
stock cams or tomei cams?
any plans for billet turbo power?
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
