Yeh, my old R31 had these rocker covers on the the later model R32 engine it had. I left them the std R31 colour and just rubbed back to ribbed tops. I think they woudl look better if they were the std R31 colour rather than lipstick red...but meh. By the time they are covered in blow-by wont be able to tell :)
Well my 20G is going to be for sale once the new engine is tuned and run in. It seems 350rwkws is about the mark for a basic Skyline doing track work with E85 these days so need to go to billet or T67 to get there.
God that is a lot of power and going ot be painful to get oil and coolant temps under control :( Whole new suspension and rear end and diff about to go in as well so the car will be like new. Just have to decide whether I want alloy tailshaft or carbon
They are Tein RAs with custome valving and different springs. From memory they are 8F/4R or thereabouts. Need to check. New stuff is the same thing just that they are GTR gear so have the forks rather then eyelets so suit the new rear end I have. The GTR gear is being revalved almost the same as my current gear and I am throwing a bit more spring at the car as I have softer swaybars now that I went from custom Whitelien to ARC so needs a bit more roll control. I may end up going back to custom swaybars if the higher spring rates do things to the pitch that I dont like.
What are they worth. Well RussGTSt is selling very similar Tein REs near new and has had them up for sale for ages as he cant move them...so I guess less then that though my hoarding whore self may just keep them as they are near new and still shiney
Yeh, back in 2001 my car was the development car used by Whiteline to develop their Bilstein kit, swaybars etc. I kept that kit to around 2008 when I changed to the RAs. I almost got the Bilsteins rebuilt to be a little more racey but the Teins being alloy body pretty much sold me on them.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
