Nice to have a fresh engine again. New motor makes the same power as the last motor with less boost and earlier. Will put 1,000kms on it and do some coolant and oil flushes and then throw the new turbo on. Hopefully bag another 30-40rwkws and pop 350 :) Should make for an interesting drive at PI next month
How did you freshen it up? Nice to see that a fresh motor makes a difference to the performance. I'm preparing my RB20DET build at the moment. Going to be using a TD06SL2-20G and a Sinco top mount manifold (similar to 6boost) and other supporting mods.
Crazy to see so much power out of a little 2 litre!
Well since I am not in a habit of leading people astray the new engine isnt actually 2L. Um and its not actually an RB20...i can't even bring myself to admit what it is :) Nothing like a self loathing car owner :):domokun:
At least the engine came out of an NA R32 so at least its not as filthy as something from an R33. So its an NA RB25 that has been rebuilt with Eagle rods, Arias pistons and 25 crank. When I throw the cam gears in after easter I will throw my Tomei Poncams in as the NA cams are rather small.
I am looking for some Garret cores so that I can start building the manifolds for the twin setup I want to run. If I am going to go twin low mount lameness I at least want to have some fun fabricating all the bits
Was it still an RB20 (2litre) when you did 306kw?
Yep...1000000% Std unopened RB20 engine that I think came out of an auto Cefiro when i chased back the engine number in FAST
In tank Nismo fuel pump, E85 with ID1000s. Plazmaman plenum with 6boost manifold and 8cm TD06-20G and 45mm Turbosmart gate with R34 GTR Cooler and Z32 AFM with HKS Hyper exhaust. Guaranteed to make at least what my engine did. It was a wrecker engine when I got it and it has since done 60,000kms of 250-310rwkws with a load of track work
If I had my time again I would have kept the std inlet plenum and the Greddy exhaust manifold. The thing had a measurably better mid range and torque. The plazmaman plenum really made it into more of a top end screamer
It would still be going if it wasnt for the heater hose the split under the inlet manifold in peak hour traffic. That engine is going to get stripped down and get slowly built back up with my spare RB26 crank and my RB24 gear for whatever R31 I end up finding
good stuff roy you can be in my crew now. besides i love telling people that my rb25 had far more in common to a rb20 than a 25det. they are a rb20 in evey way bar displacement
any reason you put a rb25det crank in yours?
I didn't put anything in it. I grabbed it as it was cheap for what it was and have no idea about it really. Was nice to that it tuned up well and looks and sounds healthy
I bought it years ago whilst I was in India as I wanted the head in case I ever put my RB26 bottom end in it. When i took the sump off and looked at it it seemed too good an engine to strip so just kept it and threw it in when the RB20 had the overheating problem
Pretty happy with how it turned out. Pretty happy with the power it makes...just to see how it holds up to being raped at the track
398854_10151838547609741_1680740710_n.jp
I hate myself :(
But, the cheapest way I could get the car back on the road ready for a track day was to use a spare engine that was laying around. I grabbed this engine cheap years ago as it was cheap and externally looks like an R32 RB20. Thinking was if I ever get defected then I would put it in with a 2.8L kit and run an XR6 GT35R bolted onto std manifold for legal thrills to clear defects and be stress free
I am going to strip down the lil 20 over the coming weeks and see if it was just a headgasket and if the head and block come back crack free going to slap it back together with a refresh and get some more exprience with building engines.
Then the abomination that sits between my strut towers at present can come out and be sold. Should be easier to sell now that I have had it running and it looks to be a good engine and potential buyer can hear, see and even drive it before removal
I can already tell you I dopnt like the character of the car. It has way more power down low that makes it spritely on the street...but feels flat. People can say it maky be quicker but doesnt have any character or top end pull that the 20 had:( LOL time for a bigger turbo to get some lag back :)
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
