Just put a Viper V10 in it.
I want to put aJudd V10 in it. But at 100k never going to happen. I have often wondered why people put Chevs in them when for US 5-8k you can get a Viper V10 :) I have thought a lot about it but this is my street-club car and struggle with minor mods let alone something like that :(
What you really need is a L Series with triples. Much more power :D
No to L series....yes to triples!
have you seen DrDrift's T51R LS1 in his 4 door 32? 440rwkw on 11psi ! sounds amazing too :)
I will post this to show why i think the 8cm would still be a great thing on an RB25 if you were running E85. Without stressing too much about boost you can see the boost control seemed ok with the 8cm and with some tweaking would have been able to get it right. These are not close to full tunes, but enough to get an idea of which way the setup was going
So the cams gave a sniff that there was more to come. The new turbo has given a sniff that the setup is moving in the right direction.
Seems my R32 is more 58 Plymouth Fury and she doesn't like the extra cubes in her and is playing silly buggers somewhere in the setup. Think dirving around with a head gasket issue with condensation in the exhaust on biref trips etc may have collapse the muffler in the 11 yr old HKS exhaust. I hope its something as simple as that because there seems to be an odd restriction somewhere that means we make ok power but not what we shoudl be :(
Meanwhile, I need this spend to stop so I can count my cash and go buy my Sierra an 80s dance partner at the end of the month
Tomei Ti cat backs are cheap at the moment :)
Was in an R34 GTR with one the other day. No way I am buying one of those exhausts. They are loud and sound likle poo compared to the Trust Ti. No idea how they flow...but IF its a dead exhaust that was somethign I had planned on changing the next 12 months so no big shakes...just have to move it forward
Wouldn't be as big a ball ache as my R32 at the moment. Dropped the exhaust. ..no restriction. So I ripped the Turbosmart Hypergate off and tested it only to find its shagged .
So in the morning need to get replacement parts for the gate...new fuel pumps as I sm niw st 100% duty on 1000cc injectors. So obviously s fuel flow priblem.
THEN hopefully with sufficient fuel snd steady boost we can find out why the new turbo doesn't make the power hoped....almist time to throw the Trust TD06-25G at it and be f**king done with it. Money running out and still no results
OK...patience out the window with all this and costs associated with back to back testing.
TD06H-25G with 10cm housing is getting the elbow welded to its compressor cover and with the new fuel system going back to what I know.,Old school trucker turbo goodness. Fark latest tech
Hopeing teh 10cm housing is at leat as responsive as the 20G and 73HTA with 12cm housing...if so then will be fine response wise for me. Just hope it belts out some real power over and above what the 20G could
Well now green lit for Phillip Island this weekend. Car is finally making reasonable power so hopefully the maiden voyage of the bucket at a track day comes up successful and we can start to chase some small remaining issues and in parallel start chasing the sort of power we should be able to achieve.
Dont know exactly. Tuner and I agreed not to worry about a number. Just run it up, leave plenty in reaserve re fuelling and lets get a good benchmark and some kms on it. Still needs work on fuel setup and cooler piping etc etc. Is somewhere around 300-320. Depends on whether we go for 16psi or 18psi. Dont care just want to it safe to get some track miles under my belt
What time does the first session start at PI? I should be there around 12...
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
