New daily drive is currently this -
Believe it or not, when the 34 is finished on the dyno it will go back to my daily and this will be driven by Carmen or just sit in the shed waiting for the weekend :D
Fk that for a daily - not because its not a nice vehicle to drive but the petrol consumption is ridiculous!
Father in law has a petrol (booo!) 80, its gotta be up around 25lts/100km.
Depends what you like. I'd prefer concavity though, but that's just me ..
Get some CE28's! XXR are too over done, plenty of evo's around my area running this setup.
Got a mate selling a nice set of EVO rims, i could get details if needed.....
Turbo Diesel man! So far i have done 600kms and am still on the first fuel tank, still have the reserve tank to go. Previous owner said around 900km on town driving and 1200km+ on highway.....
Its better than my 34 :P It drinks more alcohol than i do............ Well............ Nearly haha
gimmie gimmie l/100kms figure when you figure out numbers. very keen to know
the newer TD Prado are quoted at around 8.5l combined. I know its 3.0 4cly compared to a 4.5 (4.2D?) 6cyl but in the end same end purpose of vehicle
Edited by barraspalding
the newer TD Prado are quoted at around 8.5l combined. I know its 3.0 4cly compared to a 4.5 6cyl but in the end same end purpose of vehicle
Will be hard to work out exactly as the speedo is out :P I am working roughly on the % at the moment..... I can let you know how many L it used on a trip to VIC in a fortnight!
I'm sure Tez already has some Ralliart items lined up in his garage :P
Haha! Nice!
Thanks again you two!
The car still has to be complied; so I haven't driven it yet - even with trade plates.
Engine modifications are likely - but without going silly.
Cosmetic mods will be rims.
Thinking of getting a concave look with slim spokes like XXR-527 or ADVAN RS. Any opinions on those in 18x9.5 +20 or thereabouts?
Looking forward to see it :)
Google maps the distance, figure out the fuel L's used... carry the 1's and such.
Or get that speedo fixed. Assume its the massive penis extension tyres that have thrown it out?
Yep can work that out easily enough!
The speedo seems to be sitting below the 0 mark and stays that far out the whole way! Surely the tyres are making it out a bit yes BUT to 20km/h haha
And the owner did throw in another set of rims and tyres too, but its a part of the fun driving around in a mini monster truck :P
Ye older landcruisers and patrols are aweomse! Built like tanks and can take a lot of punishment.
Don't build cars like that anymore.
Fuel is a small price to pay really when driving 2+ tonnes of "get the hell out of my way" haha!
Lol, so far its proving to be pretty good on fuel! 2 weeks of DD and i am still on the first tank and that included a 4hr drive on Saturday exploring the coast! :D
They seem to be built pretty tough and people tend to move for it haha!
My only complaint with it is the window tint at night, cant see a farken thing! Looks awesome and is nice and private for day use but night time is a bit annoying!
Well that ain't bad at all!
And I guess changing the tint isn't too harsh of a mod really cause you need to see where you are parking at night ay.
Going to drive it to VIC and will be at night, will decide then what to do... It should be a comfy trip from my impressions so far! It's so quiet even though it had a straight through 3" exhaust.... I'll admit, it sounds like a tug boat at idle though lol
Haha yeh that's one of my little things with the diesels. Would pick the petrols for that reason although you instantly lose with the fuel ay. But i still love those sub tanks!
  • 4 weeks later...
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
