Hello
I am wondering which is best and makes more since money wise, to upgrade my RB 20 or put a RB25 or 26 in.
My goal is 300 plus horse power, 350 if possible. I want to have a car that is quick and good mid range which can hit it if I have too. I do not want a laggy car.
Is it better to put a RB25 or 26 inside?
I live in Japan, so I will buy parts here, cheaper. My R32 is manual, so besides engine, wiring harness, computer, and transmission from a R 33 or GTR what else would I need?
Or should I build my RB 20?
Help please
  • Replies 60
220-250rwkw.
RB20 will do it safely enough, as will a RB25 or 26
Just comes down to how much you want to spend, of which you've not said.
Pretty basic though either way.
RB25 and put a GT3071 on it IMO, same as the billions of other people before you now.
+1
I do however also have faith in a basic RB26 swap. The RB26 will land you more than what you are looking for on OEM parts. The RB25 will require a little more money thrown at it (ecu and turbo upgrades) to make that power.
You can expect 260rwkw~ from an RB26 with exhaust, boost and remap (the stock ECU is remapable). The same mods from an RB25 will see roughly 200rwkw (but you will need slightly more than just an exhaust and remap).
GL.
220-250rwkw.
Well
I would put the engine and transmission in with help from people who have done engine installs .
I estimate that I can find a 26 engine for free(someone has one in storage but has abandoned it possibly) or get one for about 1-2000 dollars.
So my price range is about 3-4000 dollars to do this. Also Rb 25s are about 500 dollars used here. So thats even cheaper.
I am wondering if it makes since to put a bigger engine in instead of modding the RB20. All work for the install can be done by myself and help from people who know what they are doing.
What is this slump thing that I read about here with the RB 26 that needs to be modified to fit the R32? Is this only if I do not use the GTR transmission? I am looking to use the R32 GTR engine and transmission if I go the RB26 route.
What are some bad points about the 25?Help please
Hey mate,
For $500 you can't go past the RB25...
When you put an RB26 in you will have to modify the sump. This is due to the RB26 being a 4 wheel drive motor so you will have to look after the front diff as your GTSt doesn't have one...
Hope that helps.
if the 26 is free then i think you know the answer
Just if I do the 20 besides exhaust, intake, inter cooler, bigger fuel pump, injectors, head gaskets, ecu tune, what else would anyone recommend I do to put the 20 at 300hp or over?
the biggest difference between a 20 putting out 300hp and a 25 putting out similar power will be the low down power. the 25 will leave the 20 for dead in the lower rev range
I know the low end is not so good. How can I improve on the low end in the 20?
*note car will be off the road for years...
wut? my car was driving with the 3L for nearly two years, the reason it is off the road now has nothing to do with the fact it has a 3L. If you really must know, the whole RB30DET conversion was done in a weekend. Drove it in Friday arvo, drove it home in the wee hours of Monday morning. It's not fkn rocket doctory.
My point was, there's not a whole lot you can do to get more low down out of the RB20.
Edited by bubba
My point was, there's not a whole lot you can do to get more bottom end out of the RB20.
N2O haha
I'm going to have a crack at some 50/50 E85 soon and see if we can gain some bottom end grunt :D
N2O haha
I'm going to have a crack at some 50/50 E85 soon and see if we can gain some bottom end grunt :blink:
bah at quoting before I edited :D
I'd love to run straight E85 but until it's readily available over here (read: not having to buy it in 200L drums) I cbf.
An rb20 will always be alittle doughy down low....its inherent in the design of the engine...small capacity and short stroke...there is not much at all you can do for it down low...just make sure it screams once it comes on boost...
And IMO...if 300-350rwhp is the goal...the rb20 will make it quite easily...and it'll be a heap of fun too...and if necessary...for that extra kick in the pants...run E85...the extra ignition timing you can wind in will make it a lot more responsive...
I do not want to be a weak geek on the street. I am not looking to become fasty man, but I dont want to be passed by VW or Non STI Subarus or The ugly Nissan Fugas and their so called Skylines that came out a few years ago, and mazadas and S-14's and S-15's.
I want to be able to hang with the Toyota Mark IIs and R-34 GTTs and others..
Edited by 335
if you want to "hang" with the R34's then forget about the rb20. they are a waste of time IMO. if you want more low end out of it without going broke then do what everyone else before you has done and get an rb25. for your power target the rb25 is more than adequate and very cost effective.
it is by far the most economical way to make more torque
but then im biased, i have an r32 with an rb25 and i love it! and i've always been of the opinion that building an rb20 is a waste of time. you can polish a turd all you like but its still a turd.
Edited by jonboy
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
