  • Replies 41
AV is the correct one. that makes PLENTY of sense to me.
Awesome :P That one in particular makes VERY little sense to me ;)
FYI guys, I realised that some of the smaller PDFs can be translated using Google! http://translate.google.com Just hit 'Upload a document' and then Browse to the locally stored version of the PDF. What it does is conver the PDF to html (strips out the images - so if theres any text in the images you want to read, gotta work it out manually!) and then converts it to english/engrish. Some of it is VERY retarded, but thats just because it has no idea what the word(s) is so its tried to spell it out phonetically eg "Front seat Saidoeabaggumojuru" is "Front Sear Side air bag module" :D So what I then do is have both up on screen (Side by side) and scroll from page to page that way you can look at the pictures and translations at the same time! I couldnt get some of the larger PDFs to translate though :(
Rearrange the text, stick a jpnz logo on it and slang for 200 bucks..
I was thinking the same thing.. I have a PDF printer so given enough time it could probably be translated by a group of us anyway.
Edited by Chris Rogers
given that most of what you guys need is here already and duncan provided the link for 'translation' how about we all take a pdf and rework it to english. I have the AV one open now and I figure I can sort that one to a point. if the PDF is not locked I'll attack it with acrobat and pop things in the right spots.
who's thought about doing the same thing?
as a marker (for looks/feel of the documents) also have a english G35 sedan document to work from. the layouts look quite similar to what I'm used to looking at.
I was thinking of doing the engine mechanical section anyway, good idea Chris. Could take a while for each section, to get it reading correctly.
true but with a collective effort we acheive what we originally wanted - english service manuals. I can do the electronics side of it to a point. some of the diagrams are in japanese but that is easyish to sort out via a mate of mine.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
