Lotus has revealed an ultimate track day toy at the Monterey Motorsports Pre-Reunion. The new Lotus Exos Type 125 is an F1 inspired track car that uses Formula 1 technology and a Cosworth V8 engine.
The chassis is a carbon fiber monocoque with a wide front wing and the narrow rear wings similar to the 2009-spec F1 cars. But the resemblance does not stop, it also has the coke bottle shape, top exit exhaust, shark fin engine covers, carbon ceramic brakes and a carbon fiber pushrod suspension. Inside the cockpit the F1 technology continues with paddle shifters to control the semi automatic gearbox as well as a multi-function screen on the steering wheel controlling all the parameters.
Behind the driver you will find a detuned Cosworth GPV8 engine still producing 650bhp with a 10,300rpm red line. The car as a whole weighs in at just 650kg, achieving a power to weight ratio of 1000bhp per ton. This engine is designed to run 4500km between rebuilds and has a starter motor so that you do not need a support crew to be able to run the car at the track.
Lotus plans to build 25 Exos next year at a price of one million dollars a piece. The Exos program will also include five driver events at various race tracks that will allow the owners to slowly come up to speed with the performance of their new car by getting instruction and advice from a variety of current and past Lotus drivers.
If you are interested please contact Lotus for more information.
http://www.teamspeed.com/forums/aston-mart...5-revealed.html
Bike? No thanks...i still live in hope that one day i will be banging top quality broads on a boat somewhere in the world. That dream includes having both my legs, arms, all fingers and toes and a functioning Johnson...well at least one that functions as well as it currently does
I would LOVE to have one of these. Problem is I would never fit in the bloody thing. :blink:
Mark Webber skinny I aint.
Edited by Tektrader69
Wonder how similar the chassis is to their current F1 car... Would be a great way to get around the testing ban. :worship:
The chassis itself might be similar, but the suspension, aero (massive rear diffuser, different bodywork) and wheels (15" with Michelin tyres compared to 13" with Bridgestones) are all very different.
Well I kinda thought buying this car was announcing to the top quality AND loose moraled broads that you had a non-functional Johnson.
I would LOVE to have one of these. Problem is I would never fit in the bloody thing. :woot:
never fear mate!
It says it will also provide nutritional advice – though doesn’t suggest this is to help owners to squeeze into the race car’s cockpit.
http://theage.drive.com.au/motor-news/the-...0811-11ysk.html
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
