Yeah so haven't been here in a while.
Also haven't driven the GTR for about 3 months. Too many d!ckheads with them, too much attention and stress. Does about 1000kms a year.
Should I sell it...? and if so, how to put a value on it??
hi to all who I haven't seen in a while too :blink:
https://www.sau.com.au/forums/topic/332419-been-a-while-should-i-sell-the-gtr/
Marcus!!! How you been? long time no see.
Welcome to the club, although I've done around 600kms in 2 years.... :worship:
You have one of the cleanest, well modded 32 GT-R's around, and it's an Aussie delivered one too!!!
Worth good dollars that's for sure....
You'd have to sell it through Shannons or similar type of Prestige Auction house Marcus.
You won't get a good price otherwise. I think one went for around 40-45k recently that way (ADM 32R)
Oh, and come out and say hi once in a while you rude bastard :)
sorry ash, jack, dan, al et al... :woot:
I'll visit more often!
I still love driving it but it's less and less frequent. Also there is a x-fer case noise that needs to be looked at... so maintenance/insurance/rego is a stack and it doesn't much get used.
Thinking of taking it out on w/end for a blast... cousin just got a 3.8 GT3 so want to see how the old girl goes up against it
Keep it mate. Things ebb and flow, and when things slow down having that car to enjoy or go for drives in would be pretty awesome. Its a low key thing that would pass 99% of inspections as the thing is pretty stock. You seem to be doing plenty of travel with work
you really get hassled and stress about driving it?
I drive mine nearly every day and nobody even bats an eyelid... I pretty much get ignored and I like it that way... IMO getting rid of the personalised plates helped as well
that said I don't drive Fri Sat night and try to avoid the 'hotspots'
I just spent a packet traveling so don't have the coin to track it at the moment but I still enjoy driving it... even at the speed limit;)
I say keep it... if yours is the one I'm thinking about you put a heap of time and effort into getting it right... unless your desperate for the cash tuck it away until you get motivated again... my 2c
I'm with NickR33 on this one.
hi to all who I haven't seen in a while too ;)
I hope you are not letting these little things annoy you to the point of selling your car?
I drive mine everyday to and from work.. sees about 70+ k's a day, with personalized plates and like Nick says people don't really care.. been pulled over once by Graeme on the forums here but it was pretty much for a chat :thanks:
keep it mate. if you still enjoy driving it, and can afford to keep it then just let it gather dust.
as for the limited kms i guess it all depends on where u live and the cops in your area.
i live in knox which most know is a bad area if you have an import but i do 400-500kms a week without any issues.. touch wood :)
Being an ADM GTR, I'd definitely sit on it, because the values are only going to go up and you'll be kicking yourself if you sold it too soon.
Are the price of a 32 gtr gona go up?
why..
Its really good to hear this, making me want to keep my car even more!! hahaa sik.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
