So my R34 GTR with GTSS', poncams/gears, Z32s, pfc, HKS/Nismo dumps-pipes-zorst, bigger cooler, hard pipes, profec, splitfires, etc. made a poor 290awkw with some serious boost issues. Big plug to Unigroup who seem to have sorted the boost issues that i struggled to find on my own...
Now i am up for a decent retune and am seriously considering jumping on the E85 bandwagon, since there are some good supporting mods to start with. My fuel setup is all Nismo, including intank pump, 600cc inj's, and reg. I was thinking bout upgrading to 1000cc ID's, running E85, 22psi+, and aiming for mid 300's at the wheels.
What do you guys think of running the Nismo intank with 1000cc ID's to support the power level, and also doing it on standard bottom end?
https://www.sau.com.au/forums/topic/332614-e85-fuel-setup/
  • Replies 87
Posted Images
Id be getting a small undercar surge tank and one 044 pump or similar should do the trick for that power level..Only cost about 300$ too, cheap for peace of mind..
If you get the latest PI magazine theres a story on it, and a free dvd... :D
Edited by Arthur T3
https://www.sau.com.au/forums/topic/332614-e85-fuel-setup/#findComment-5394509
If we're talking only one 044 pump, wouldn't the Nismo pump be close in flow rate comparison?
https://www.sau.com.au/forums/topic/332614-e85-fuel-setup/#findComment-5394524
i cant see why you cant make 300-330ish with the setup you have on just 98.... is the extra 20-30kw really worth screwing round buying e85 all the time? Unless its at a servo near you... or the car is track only....
https://www.sau.com.au/forums/topic/332614-e85-fuel-setup/#findComment-5394553
In the perfect world it would make 330awkw, esp with all the brand name bits on it... It only made 290 and drove like a pig, although the old tuner was clueless and ignored the boost issues too. Just want to make sure it reaches its potential, and the possibility of it exceeding expectations and making something silly like 370+ would be insane!!
Servo in the next suburb is selling E85 as of next month.
https://www.sau.com.au/forums/topic/332614-e85-fuel-setup/#findComment-5394577
Sard 700's (or the 800s) would be fine for that power. Minor rail bump if anything.
I think Nismo have 740s for RB26's as well?
Nismo pump flows fine for 400rwkw on PULP/700cc + a minor bump (circuit cars, no surge tanks in them)...
So E85 @ roughly 360rwkw would be similar in terms of volume/supply
https://www.sau.com.au/forums/topic/332614-e85-fuel-setup/#findComment-5394579
Most you'll get is around 30-40rwkw gain from E85, going by what most other results indicate at least anyway :D
So 370 would look like the limit (in theory).
https://www.sau.com.au/forums/topic/332614-e85-fuel-setup/#findComment-5394585
Your lucky man, i gotta drive 1.5hours into the city to get E85. But im pritty sure holden realised some Eco crap last week that runs on E85 so hopefully it comes more avaible.
https://www.sau.com.au/forums/topic/332614-e85-fuel-setup/#findComment-5394592
You could always put a big single in tank like an A1000 for that power it shouldnt be stressed and then no extra lines and tanks etc
Thats an 800$ pump, for that you get 2 44s and a surge tank...
Maybe I just like surge tanks, but thats how i was going to set mine up anyway..
You dont think its worth it?
:D neither does nismoid.....
Edited by Arthur T3
https://www.sau.com.au/forums/topic/332614-e85-fuel-setup/#findComment-5394598
By any chance do you get your car serviced at Autostyle? I sort of recognise the plates
Most people will say you need an extra 30% for E85, thats not always the case, my car proved it was way more than 30% under full throttle, but then again every setup is different :D
https://www.sau.com.au/forums/topic/332614-e85-fuel-setup/#findComment-5394617
^ depends on how efficient the setup is and all the usual variables that come into account :D
Some cars respond much better to fuel and all of a sudden you can get heaps more out of it, same token fuel use then is higher also.
https://www.sau.com.au/forums/topic/332614-e85-fuel-setup/#findComment-5394625
Here is the link to Caltex planned rollout of E85:
http://www.caltex.com.au/ProductsAndServic...s/BioFuels.aspx
Marketing manager told me plan is have most running by late September, early October. So that might make it easier for some.
Engine bay looks almost stock, i don't want the look of pumps, lines, surge tanks in the boot.
The 740's are side feed Ash. From what you describe pump maybe close to a dangerous limit there.
https://www.sau.com.au/forums/topic/332614-e85-fuel-setup/#findComment-5394632
Thats why i said undercar tank...can get one that holds 2 44s..bolts up under the boot floor
135$ on ebay.. ..
http://cgi.ebay.com.au/Fuel-Surge-Tank-Und...=item3356ba225b
https://www.sau.com.au/forums/topic/332614-e85-fuel-setup/#findComment-5394651
You mentioned unigroup fixed your boost issues, what sort of power is it making now?
The car should be making in the region of 320-330awkw with the hardware you have currently, and if not, somethings not right and I would be addressing that before trying to chase more power through switching to E85.
https://www.sau.com.au/forums/topic/332614-e85-fuel-setup/#findComment-5394652
Haven't been back on the dyno, currently sitting outside holding off for a week to decide whether or not to go E85.
https://www.sau.com.au/forums/topic/332614-e85-fuel-setup/#findComment-5394659
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
