I'm buying it purely for the Zombies mode. I still crank out WAW Zombies, so this should be epic.
cant u get it with hardened edition. i got the prestige edition for mw2 and the special edition for WaW but only used the nvg's twice and lost the canteen thing from waw so no point in rc car for me
Pre ordered mine a few weeks back and had it set in my mind it came out early this month rather than next month and only realized the other day ;)
Interesting to see if trayarch can pull off a Modern style compared to their failed attempts at War type COD's
i really didn't get what the hell was so bad about COD-World at war.. everyone hated it - what's NOT cool about having a japanese dude jump out of a tree trying to kill you - and you BLOW HIS FKN ARM OFF WITH A SHOTGUN!?!?!
how can you NOT like that game?
for anyone who doesnt want to pay $100 for the game you can get it from http://www.play-asia.com/paOS-13-71-bp-49-en-70-3ts2.html
the only difference is sometimes the cover has foreign writing but game is always exactly the same. and black ops could never beat mw2
I agree was a fantastic game & still play it alot !
