  • Replies 467
I just make a cut in them with tin snips, then use some vice grips to tear them off, kind of "rolling" the grips to help tear the metal if you get what i mean?
They're just an interference press fit onto the hub, no need for major surgery to get them off, just bend/tear/snap them off :banana:
It can be fun getting them off - lots of twisting rolling and yanking with vise grips and bull nose pliers. I also used a hammer and chisel to clean up the last remnants off the back of the hub.
Look at the little bastard cowering in the background after I got all tony danza on its ass
i only remove the front stone guards, or else they would be hitting my disc :S
anyway received my pfc d-jetro in the mail today :D however im unsure if the sensors send with it are the map ones (as they look nothing like the normal ones i have seen other on the net)
thanks :D i wasn't sure as they look very similar to the apexi boost gauge senders i had.
now just need to work out how to install them and off for a tune
Yeah electronic boost guages use a map sensor as well hence why they look the same - same thing with boost controllers (avc-r etc).
You just need to hook them up off a good vacuum / boost source off the intake manifold. It would be a bit different with the rb26 having individual throttle bodies - I have only ever installed map based ecu's on single throttle body systems. You would want the vacuum / boost seen after the throttle bodies.
Speak to someone who has installed d-jetro for sure!!
Thanks did some looking looks like you need to tap some fitting onto cylinder 3 and 4 in the plenum.
So now just need to wait till i get my hks afmless pipe and blitz ebc (id3) and see it off toget a tune. Atm i increase boost to 1bar (bleed valve) and the cars feels alot better still laggy but pulls harder might just keep the n1 turbos for the moment and see what sort of times i xan get at the track
does anyone know how to determine the spring rate of a spring?
i have just purchase a set of coilovers to start off with, however they have had their springs swap for some swifts springs and the owner doesn't know the rate
Usually it is marked on the spring somewhere.
Bloody easy since most of the steels used to produce these springs have very similar properties.
Try this calculator:
http://www.racingsuspensionproducts.com/spring%20rate.htm
thanks :geek: im hoping the spring rates aren't too crazy!
btw could someone explain to me what the helper springs do? (extra spring at the top of the normal spring)
thanks :) im hoping the spring rates aren't too crazy!
You want crazy spring rates, the car will handle better that way
:P
Keeping the main spring captive under full droop is all they are there for.
The purpose of them varies depending on if they are helper springs or tender springs.
I'd assume being japanese they are probably only going to be a helper spring.
Article about Helper Springs vs Tender Springs
Sorry my mistake they come with Assist Springs
Just because i wish to run 10/10 doesn't make them crazy spring rates, what i am worry about is that the spring rates will be in the 15 region as its not uncommon to run such rates in japan.
I understand that the general thinking is that 10/10 will be too stiff. However i have good experience with those spring rates in my r33 track car and will be testing similar rates out in the gtr. I plan to start with 6/8 combo however i need to do some reading on this Assist spring and select the correct rate for that combo. If 8/6 doesn't work i will move to 8/10 etc etc
till i find the right setup for my gtr
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
