  • Replies 156
don't get all sooky just because you've shot yourself in the foot and been proven completely wrong - you came on hear telling me i'm talking crap, i refute it and show you to be wrong and now you're having a cry - man up dorothy. It's not google numb nut, it's the fuel i buy from my local E85 station
anyways, it's a pity such a monster of a car has some ignorant businesses jumping on for an exposure ride..
anyways, nitto/paul/trent, what fuel system are you running on this thing??? id2000's and 11ty 044's?
so did it or didn't it get on the track?
Still with the big mouth---------I was not going to get back on this Forum but seeing you think you know everything, I just wanted to thank you for the new customers and resellers you have sent my way, for that cheers mate..........And thank you all for sending me emails telling me how much a dick this guy is.....by the way come and say hello any chance you get chump.
Piss off already, you remind me of every little shit headed 14yr old boy who thinks he's king shit behind a keyboard. How about you get out there and spend some time selling your fuel? If you were so confident, you wouldn't need to come back here every day to spout so much more nonsense. Your grammar is worse than mine, it's beginning to make me sad.
Edited by Trozzle
Yes! We're well aware that the brake light is out...
We had a professional photographer booked for Powercruise, however he was unable to attend due to an emergency, we found out early the Friday morning so that sucked!! We didn't have any vid cams there...
But, there is more footage out there, we're just waiting for it to be put up.
SS8-Gohan - yes ID2000's (at the moment only 1 set, but two will be going in), Hypertune fuel rail, 2 x Magnafuel Pro Tuner pumps, custom surge tank, bigger lines etc. etc.
Of course it went on the track! You people just didn't look hard enough if you were there...
Edited by NITTO R34
How do you find the magnafuel pumps? How would you compare them to weldon pumps?
.... 12x 2000cc injectors.. Can't wait to see the results!!!
Cheers
Justin
It definitely went out on the track, I have the brown undies to prove it.
If I can find my damn USB cord to upload the vid from my BB, I will post it for all to see. Footage is mostly of the sky, then the floor between gearchanges...but at least you can hear it...
another video lost quality in the compression but oh well. skip to 50secs if you wanna see race
Good vid!! I really wanted to stretch its legs in 4th but there just wasn't enough room. It was hard enough getting space to max out 3rd, and that is when its starting to feel really strong.
i want one :action-smiley-069:
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
