Caught person doing 140-160+ in 80 Zone who also went more than double the alcohol limit. The Drink driving ban is canceled out by the speeding ban. Impound, 1100 in fines and no driving for 12 months.
Lucky for him he didn't kill anyone. I'm glad I was doing laser duties when things were quiet and now have him off the road!
He wants to contest it saying his Honda Jazz doesn't go that fast.
https://www.sau.com.au/forums/topic/334931-worst-driver-of-the-week/
  • Replies 167
you boys should be allowed to legally tazer the shit outta them LOL.. maybe this will teach them not to drink and drive.. anyone who repeats drink driving or is double the limit should automatically have the alcohol breathalizer installed to start their cars..
If the speeding fine overrides the alcohol.. Does that mean if he gets off (by chance) that he can't be charged with the alcohol? And LOL as if a Jazz can't go 140...
The speeding doesn't over ride the alcohol as such but when you lose it for 12 months for speeding the 11 month suspension for the alcohol becomes irrelevant. Should be served one after the other not concurrently but what can you do. I guess they don't expect to have people drink driving and speeding to such an extent.
I agree, should also be the same for jail sentences, sick of f**kers being found guilty for 6 or 7 offences but only doing a few months because thats what the longest sentence is, in reallity, if someone knows there going to jail for 12 months why dont they go on a crime spree, there not going to get a longer sentence.
Edited by W0rp3D
i was thinking of mr eps lol
oh some of the posts in here remind me of rants to the Herald Sun. Given that most of you don't know anything regarding the context of the offences (apart from Graeme), perhaps you shouldn't be so quick to condemn?
TBQH I'd rather get done for drink driving than speeding, everyone I know who has gotten done has gotten off a LOT lighter with suspensions / fines, apart from the whole interlock thing.
So...you're saying he probably had a good excuse to be doing 60-80km/h over the speed limit while drunk? Well forgive us for assuming he was a baddie! Obvious devil's advocate troll is obvious.
no trolling brah, i'm just saying that you've been given some facts without context at all, and the usual white knight types give the usual reaction along the lines of "BURN THE WITCH1!!!!!!1!!!!"
if it was a member on here who had been done for an accidental clutch slip / wheelspin / impoundment, you'd all be up in arms, so I'm just pointing out the obvious here :P
if it was a member on here who had been done for an accidental clutch slip / wheelspin / impoundment, you'd all be up in arms, so I'm just pointing out the obvious here :)
speaking of 'obvious', it's quite obvious a little clutch slip does not lead to you being propelled to 60-80km/h over the speed limit nor does it put enough alcohol in your blood to send you over 0.05. Being over the legal blood-alcohol limit and while doing 60-80km/h over the speed limit are not little split second mistakes as your clutch example so the comparison does not work hence people probably would stick up for that person where this is complete disreguard for everyone including the driver themselves.
maybe it was boz in the car.. and he was travelling with one of his gf's.. and he knows that with his gf in the car.. there is no way power to weight ratio can get that Jazz up to 140..
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
