Hel Stainless Steel Braided Clutch Line Group Buy
  • Replies 187
Ok, the lines are getting picked up by Fedex tomorrow meaning I shall have them late next week some time.
One small hicup, the GTT lines are not yet made and will be sent seperately in a weeks time so every one doesn't have to wait. Hope that is ok.
Cheers
LINES ARE HERE!
I'll start getting them ready today and try and mail them out tomorrow before work or worst case scenario on Thursday.
LINES ARE HERE!
Cheers Phil
They have all been sent out today. People in QLD should probably receive them tomorrow and every where else on Monday or Tuesday.
Blazk, Pintaline and Gimps-34 I will let you guys know when the GTT clutch lines have arrived to me.
Cheers guys
is the clutch line meant to go from master to slave cylinder or master to separation box?? any problems with by-passing the separation box??
I'm not really sure on how the GTR setup works. For reference the GTST line is quite a bit longer than the GTR line.
Edited by PM-R33
Got it today with thanks mate :rant:
I'm not sure where it's meant to go.... looks too long to replace just the factory rubber line, too short to get rid of the "block"... I'm certain it will all come to light soon enough though! :P
Thanks again, great smooth GB :yes:
Too easy Ben, glad to see the QLD guys are getting them today.
Yeah I wasn't really sure on what the GTR line replaced since it was a different length than the GTST one. But I figured you GTR boys have some weird funky setup due to the AWD hence it being different :P
I think the GTST one replaces the block, but I shall soon see.
Got mine as well :D
I'm pretty sure it replaces the block, if not I'm gonna try my best to make it replace the block
Thanks again Phil. Must be hecktic at your place trying to organise all these group buys :)
Hahaha cheers guys. The people at the post office I go to always act so suspicious every time I rock up with two boxes full of express post satchels lol.
I was under the impression via the HEL website that the GTR lines were supposed to replace the whole lot, direct line from master to slave?
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
